0 Members and 1 Guest are viewing this topic. Read 2775 times.
I am currently using Corsair which is very stable. If it is an OEM computer, I will use Kingston, Samsung or Crucial.Then you might want to put into consideration that it all depends on your system board. Asus system board sometimes are picky as to which brand and chipset works, so I would check the manufacturer first. Other than that, newegg is a great place to buy. If it doesn't work, it is also easy to return them.
Quote from: Levi on 3 Feb 2007, 03:02 pmI am currently using Corsair which is very stable. If it is an OEM computer, I will use Kingston, Samsung or Crucial.Then you might want to put into consideration that it all depends on your system board. Asus system board sometimes are picky as to which brand and chipset works, so I would check the manufacturer first. Other than that, newegg is a great place to buy. If it doesn't work, it is also easy to return them.It is a Dell Dimension 9150.George
Nice setup! Are you running dual video boards with the SLI?Bryan
