Disconnect video circuit board?
0 Members and 1 Guest are viewing this topic. Read 1174 times.
rbrb
« on: 30 Jan 2007, 05:01 pm »
I'm not sure if I've posted this in the right area.  I have a DVD/CD/SA-CD player that is strictly used as a 2 channel CD/SA-CD player.  Video connections are not hooked up.  I've gone into the menu system and disengaged the digital outputs.  On the front panel of the unit there is a button to disengage the video circuits.  This is done of course so that the audio signal is not contaminated by the digital and video circuits when the machine is being used as an audio player only.
Would I be doing any harm if I actually disconnected the video circuit board from the main board internally?  It appears to be as easy as removing two ribbon type connectors between the video circuit board and the main board and the power supply connector.
Would having the boards physically disconnected be a more effective bypass than a switch?
« Last Edit: 30 Jan 2007, 05:30 pm by rbrb »
DonnieW
Re: Disconnect video circuit board?
« Reply #1 on: 15 Feb 2007, 12:25 pm »
I'd try it.  Would be interesting to hear (pardon the pun) if it made a difference.
DonnieW
« Reply #2 on: 15 Feb 2007, 12:26 pm »
Is this a Denon by chance?
rbrb
« Reply #3 on: 4 Mar 2007, 10:17 pm »
It's a Sony NS9100ES actually.  I finally got the nerve to do it.  The background seems to have become blacker.  It could be that the unused video jacks are acting like antennas and it's become quieter without the circuit board that contains the output video jacks connected to the mother board.
