Sig 30 with LS35A's
0 Members and 1 Guest are viewing this topic. Read 2287 times.
kbuzz3
Sig 30 with LS35A's
« on: 29 Jan 2007, 04:40 pm »
Has anyone tried the sig 30 with a pair of this ancient but ultra musical benchmark speakers.  They usually react better to gobs of traditional power but the sig is a different animal. I have read the posts regarding the gallos but the ls35a have a wierd impendene load.
Believe it or not this would be my second sig.  for use in my office system.  Its way too complicated to explain but i cant carry my exisiting sig to my office and dismantle in wall wiring etc.
Thanks in advance
Tubo
Re: Sig 30 with LS35A's
« Reply #1 on: 30 Jan 2007, 05:55 am »
I do not own a sig 30, but I do have a RWA Teac and two pairs of LS3/5A's, a pair of Rogers 15-ohm and a pair of Spendor 11-ohm. The RWA Teac is wonderful with them. Very detailed presentation, albeit a slightly uptilted high end, but not harsh or fatiguing. Not as warm as a tube amp paired with LS3/5A's, but very musical and faster, more incisive.
What do you mean the LS3/5A's have a weird impedance load? In my experience (and I've owned one pair for over 25 years, the other over 10) they are a very easy speaker to drive, despite their low 82db efficiency. Even an 8-watt SET 300B amp drives them to levels where my condo neighbors ask me to turn them down. I have driven them with many different amps over the years, and they sound best with tube amps of modest power (remember, they are not designed to handle lots of power). Tripath amps such as RWA Teac, Sonic Impact, and Trends also pair well with LS3/5A's (though their sound is very different from tube sound). I have a hunch that Vinnie's Sig 30 would be terrific with LS3/5A's. Why don't you take advantage of the trial period?
denjo
« Reply #2 on: 30 Jan 2007, 07:08 am »
I agree with Tubo about the synergistic match between the Rogers LS3/5As and SET amplifiers. I have a pair (15 ohm) which I have paired with the CARY 300 SEI (8 w conservatively) and despite the speaker's 82 dB, they can play plenty loud without strain. I think it is to do with the 15 ohm (11 ohm for the later models) impedance that makes them very easy to drive, especially with pure class A power.
Vinnie R.
    • http://www.vinnierossi.com
« Reply #3 on: 1 Feb 2007, 01:25 am »
Thanks in advance
Hi kbuzz3,
You'd be surprised with what you can actually drive with the Sig 30.
If Tubo's RWA modded Teac can drive his LS3/5A's, the Sig 30 is definitely up for the task (thanks for the feedback, Tubo!).  :weights:
Best regards,
Vinnie
kbuzz3
« Reply #4 on: 6 Feb 2007, 04:22 am »
Thanks all for the comments. I appreciate the insight. What i ment to say is i have driven my 15 ohm chartwells with various integrateds mostly tube.  Some very low powered like a modded dyna sca. The best to my ears was a refurbished sherwood and that i belive puts out closer to 75 watts.
mmmm maybe ill have to buy another sig 30 and give it a try.....jeeze anyone want a pair of joule monoblocks ....lol
