0 Members and 1 Guest are viewing this topic. Read 8229 times.
Therefore, I am looking for a woofer with longer excursion. I came accross the Extremis 6.8 web page:http://www.adireaudio.com/Home/ExtremisMidwoofers.htm .I have the impression that this woofer might solve my problem: it has one inch of peak-to-peak linear excursion and should fit onto my enclosure.What do you guys think? Any good or bad experience? Any recommendation for another driver?
I'm not sure any single 6" or 7" driver is going to get you where you want. I understand the Extremis is a fine driver, but you're likely to end up with an efficiency mismatch, and a single Extremis is only capable of a max SPL of about 85db at 40hz in your open backed exclosure. The first thing I would suggest if you haven't already done so is to stuff that open rear cavity. That will reduce resonance and gain up to 6db at the bottom end, because you now have a variation of a U-baffle. Since you're hitting max excursion, you'll want some type of rumble filter to filter out the lowest frequencies to protect your current drivers. Then if you need more extension add a sub. If you were able to go with 2 Extremi (sp) per side, with biamping, and an adjustable active XO, then I'd say go for it. In your case I'd be hard pressed to recommend cannibalizing a good speaker.
I think the Extremis uses a Tang Band motor. Assuming you don't need smooth response well up into the midrange, a more cost-effective route might be the Tang Band 6.5" subwoofer. I use 'em (in a reflex enclosure tuned to 27 Hz) and like 'em. Similar excursion capabilities to the Extremis, a different surround, and lower thermal power handling. In an OB application, mechanical limits will set in long before thermal limits become an issue.http://www.partsexpress.com/pe/pshowdetl.cfm?&Partnumber=264-832Duke
Bruno,Re your wall partitions, what kind of foam & fiberglass? Bass waves go thru a lot of stuff, so you may not be getting the almost IB response that you think. Cool idea though, your own audio cocoon.
Quote from: JohninCR on 31 Jan 2007, 03:48 pmBruno,Re your wall partitions, what kind of foam & fiberglass? Bass waves go thru a lot of stuff, so you may not be getting the almost IB response that you think. Cool idea though, your own audio cocoon.I do agree. However, I had a "Sound Cocoon" when I was living in NC. My speakers were not open baffle at that time. Even with a two inch foam thick hanging wall, the improvement on bass was tremendous: both in quantity and quality (actually, by far the best bass I have ever heard). IMO, the most important factor for bass reproduction is the room.Bruno
