Total Members Voted: 26
0 Members and 1 Guest are viewing this topic. Read 3381 times.
Important Update Info: Mike Rivers from Recording magazine sent me a test Wave file that shows absolute polarity can be audible in some circumstances. The polarity.wav file (87k) is a 20 Hz sawtooth waveform that reverses polarity in the middle. Although you can indeed hear a slight increase in the low end fullness after the transition point, I'm still not 100 percent certain what this proves. I suspect what's really being shown is a nonlinearity in the playback speaker, because with a 50 Hz sawtooth waveform there is no change in timbre. However, as Mike explained to me, it really doesn't matter why the tone changes, just that it does. And I cannot disagree with that.More Update: After discussing this further with Mike in the rec.audio.pro newsgroup I created two test files you can download and audition yourself. The Kick Drum Wave file (324 KB) contains a kick drum pattern twice, with the second reversed. Play it in SoundForge or any audio editor that has a Loop mode, so you can play it continually to see if you hear a difference. The Voice Wave file (301 KB) is the same but with me speaking, because Mike says reversing polarity on a voice is surely audible. I don't hear any difference at all. However, I have very good loudspeakers in a room with proper acoustic treatment. As explained above, if your loudspeakers can't handle low frequencies properly that could account for any difference you might hear.
Quote from: Doublej on 26 Jan 2007, 03:54 pmDaygloworangeI agree with your assessment of my description but what I failed to mention is that the setup was outdoors on a deck with the speakers about 15 feet apart so there wasn't any interaction between the two. Discounting the difference in content between the left and right channels it was listening to one speaker with polarity X and the other with polarity Y. When we moved from being in front of one speaker to the other it was clearly discernible difference. We both honed in on the left speaker as sounding wrong. This was the one with the leads reversed.This topic, like most regarding absolute polarity, has somehow reverted to talking about speakers being out of phase with one another. That is a completely diferrent topic, and does not require debate. Out of phase speakers (where a mono signal sounds ethereal with no real center image) is a problem with one speaker having it's leads reversed. It is not a debate about absolute polarity in recordings, polarity switches or the like. Two different animals all together.
Quote from: ted_b on 26 Jan 2007, 04:04 pmQuote from: Doublej on 26 Jan 2007, 03:54 pmDaygloworangeI agree with your assessment of my description but what I failed to mention is that the setup was outdoors on a deck with the speakers about 15 feet apart so there wasn't any interaction between the two. Discounting the difference in content between the left and right channels it was listening to one speaker with polarity X and the other with polarity Y. When we moved from being in front of one speaker to the other it was clearly discernible difference. We both honed in on the left speaker as sounding wrong. This was the one with the leads reversed.This topic, like most regarding absolute polarity, has somehow reverted to talking about speakers being out of phase with one another. That is a completely diferrent topic, and does not require debate. Out of phase speakers (where a mono signal sounds ethereal with no real center image) is a problem with one speaker having it's leads reversed. It is not a debate about absolute polarity in recordings, polarity switches or the like. Two different animals all together.OH BOY....It hasn't reverted to talking about speakers out of phase with each other unless two $50 bookshelf speakers, 15 feet apart, sitting atop a wood fence have any significant interaction between each other when one put their head two feet in front of each speaker. I certainly didn't hear the music "in stereo" that day with the speakers in or out of phase with each other.
