0 Members and 1 Guest are viewing this topic. Read 28333 times.
So after all this - was there ever a problem with your Le Amp 3's that you were sure about?
GR,How do you like the Yaqin? How does it compare to your other amps.Dennis
Great, GRacer, your comments about the amp have been like razor. You had a technical problem. The amps have been the usual suspects. After all the negative posts you suddenly come with the reason: a cheap accessory... Norh cooperated. Not as you expected. And to keep your face, you still claim, something must have been wrong with the amps. And what's wrong with the careless owner?
