Moscode 300 for sale
0 Members and 1 Guest are viewing this topic. Read 5053 times.
playntheblues
  • D-Sonic, Mola Mola TamBagui, Tekton DISE
« on: 18 Jan 2007, 03:53 pm »
I have found a set of Moscode 300's that have had the same modds done to them and again they are a match set.  So I am selling my lone 300, within the year it has had the trannys repacked and upgraded caps (larger).  I am asking $500.00 for the amp. and it is truly a great amp.
Thanks and all the best, Guy
playntheblues
Re: Moscode 300 for sale
« Reply #1 on: 18 Jan 2007, 09:49 pm »
It your thinking about the new Moscode at $4,900.00 this is a cheap way to check out the sound.  Are the new ones better, I'm sure but at $500.00 you can check it out inexpensively.  I think you will be very surprised.  George Kaye will tell you (he told me) other than the new Moscode there is not a better amp.  Now I understand you need to take this with a bowl of salt, however it says alot.
Rob Babcock
« Reply #2 on: 2 Feb 2007, 07:21 am »
Seems like a heckuva deal for someone.  Did you ever sell it?
Early B.
« Reply #3 on: 3 Feb 2007, 11:09 pm »
How many watts does this amp produce?
Can you provide additional specs? I'm mainly interested in the input sensitivity.
Thanks.
playntheblues
« Reply #4 on: 4 Feb 2007, 04:06 am »
Hi guys sorry I didn't check this ad sooner.  The Moscode 300 is 150 watts a side into 8 ohms.
playntheblues
« Reply #5 on: 5 Feb 2007, 03:17 pm »
Ok I will try to make this short.  The sale of my Moscode 300 is on hold for about two months.  My deal on the match set of 300's fell through.  So I bought a Moscode 600 and it will take George K about two months to upgrade it and I will need the 300 for that time.
Thanks, Guy
