0 Members and 2 Guests are viewing this topic. Read 11254 times.
My rec would be the Seas H1212 given your penchant for detail and clarity without harshness as I take your words to mean.
sealed alignment F3 at 39Hz and slow roll off F10 around 25. In room will be even better!)
....The other thing I was considering was having the Aircirc or HDS substitute for the tweeter.All may put you just above your budget though.Best of luck.Regards,Jeff
...My rec would be the Seas H1212 given your penchant for detail and clarity without harshness as I take your words to mean. Then the mid could be an MTM of the Dayton RS 180's or the Seas L18s. The woofers could be either the Dayton RS270's or the Seas L26, but I'd go for two in each speaker....
Christof,When you owned the Chalcedony, did you have a problem integrating the side mounted subs with your room?I like the sleek profile of the MTM with side mounted woofers, guess the problem is where the xo point is for integration.
I'm sure others will disagree - just my opinion based on dealing with many different types over the years. I can't remember a single time dealing with a side woofer speaker in a room < 25' wide that we didnt' have isssues.
Side firing woofers IMO are an issue in room. They tend to create large FR swings due to direct cancellation from the side walls unless you have a very wide room. Many vendors use this design. I've had to work around more than one of them when trying to get a speaker to integrate into a room properly. One wouldn't think the SBIR would be any worse than with a front firing driver but based on my personal experience, they're much harder to get to integrate correctly - especially if you have less than 6' or so from the side of the cabinet to the side wall. Also, when mounting them on the sides, you're automatically putting the woofer center closer to the wall - and significantly - with the front baffle the same distance from the wall. Facing them toward each other is just a different set of issues.I'm sure others will disagree - just my opinion based on dealing with many different types over the years. I can't remember a single time dealing with a side woofer speaker in a room < 25' wide that we didnt' have isssues.Bryan
Josh,Great write up!
I would like to add my own "personal" opinion to what you mentioned regarding the Nextel drivers or any drivers for that matter. Distorsion measurements are a good indicator of a drivers performance but certainly not the only factor to look at when selecting a driver for a particular project. In the end the sound is the deciding factor based on the design goals and what the client or designer is looking to achieve.
Having owned several Seas Excel based systems I opted for the Seas Excel Nextels for a slightly fuller, warmer presentation then the Mag cones. Is there more measureable distorsion?.. maybe but they provide the exact sound that I was after so the design objective was met. If distorsion was all bad people would not be using tube gear.
I just noticed that my suggestion was damn close to Rick's Peridot. I hadn't look at his offerings in a little while so I hadn't noticed the similarity. Replace the ribbon tweeter with the H1212 and you have a slightly smaller format of what I described.
I of course think you should ask Rick his opinions too, as he has far more experience then I* or others here. He might suggest something a bit different based on his experience with how it all fits together.
Enter the next design specification:Individual boxes for tweeter, mids and bass drivers, similar to these Art Loudspeakers. This design specification is not intended to effect driver choice but it may have some importance.
Wow, seperate boxes will make for a William "The Refrigerator" Perry size speaker.
