My cdp needs to gain some weight
0 Members and 1 Guest are viewing this topic. Read 5042 times.
tvad4
Re: My cdp needs to gain some weight
« Reply #20 on: 16 Jan 2007, 02:02 am »
I forgot that my wife has some 2.5 lb ankle weights (containing iron).   I'm supposing she will feel sorry for me when she sees it on the cdp.  The cdp already has some damping material on the inside.
I might be overreacting, but I'd be concerned about creating a magnetic field near the power supply/electronics of the CDP with a chunk of iron...even if it's covered with rubber.
That's one reason that lead is better. Non magnetic, right?
woodsyi
« Reply #21 on: 16 Jan 2007, 03:52 am »
I have used weight on top of my CD transport with metal cones on the bottom to good effect.  The additional weight really couples the unit to the rack which in turn is anchored to the floor.  If you are using isolation type such as rubber feet or damping material on the bottom, I am not sure the additional weight does anything.  I went to a golf shop and picked up 5lb lead ingots for cheap to use as weight.  They get these for use in customizing clubs.
