Looking at the HT3...
0 Members and 1 Guest are viewing this topic. Read 3564 times.
RawB8figure
« on: 7 Jan 2007, 07:45 am »
Hi,
I am looking at building the HT3 for just a living room stereo. What speakers are these comparable too. I haven't had a chance to listen to them, but am wondering what other people would consider a comparable speaker to the HT3.
RAW
Re: Looking at the HT3...
« Reply #1 on: 7 Jan 2007, 05:31 pm »
http://www.audiocircle.com/index.php?topic=33541.0
http://www.audiocircle.com/index.php?topic=33187.0
http://www.audiocircle.com/index.php?topic=27898.0
http://www.audiocircle.com/index.php?topic=24534.0
Robert
This is a few reviews on the Critics circle plus all the reviews on our forum here.
By the way Robert if you want a pair of MDF cabinet built with no finish these can be ordered now as well.We will have the HT3 MDF cabinets as a option for the kits for those who want MDF cabinets but no finish is applied.(These MDF cabinets will be available for most kits)
These cabinets will come MDF all pre machined , they will require some sanding or rounded corners may be also machined for those who want to apply the veneer them self.
This takes 90% of the build process out of the picture.People can then order the unfinished cabinets and apply a painted finish or give veneer a try.
RawB8figure
« Reply #2 on: 7 Jan 2007, 08:10 pm »
Thats sounds awsome, how much and when will it be available with built cabinets.
RAW
« Reply #3 on: 8 Jan 2007, 01:00 am »
These MDF speaker cabinet prices (per pair if not noted)will be offered as a option item for the kits we sell, all of these will be loaded to the site this week.
All the prices for these MDF cabinets (per pair if not noted) include packing and shipping no other shipping cost but the cost of shipping your speaker kit which ever you order.All MDF cabinets will be shipped via FED EX Ground if not noted.
HT2 $245.00
HT3 $299.99 PROMO SPECIAL LIMITED QUANTITY$349.99 after promo
HT8 $750.00
HTFR $349.99
LX II $595.00
APEX II $1999.99
APEX C $999.99 (each)
All cabinets will come with square corners, rounded corners with a 3/4" radius can be machined for an additional change.Best to phone in to confirm radius you would like.We use 3/4" as a minimum radius and up to 1" on some cabinets can be done as well.
RawB8figure
« Reply #4 on: 8 Jan 2007, 03:49 am »
Thanks for the info Al.
Well what I was going to get were the B&W 603 or 604 S3 speakers for my stereo set-up. Can anyone campare the two speakers.
audioferret
« Reply #5 on: 8 Jan 2007, 04:46 am »
The B&W brand is nice, but if I was offered a trade, I would feel no desire to replace my HT3s.  The B&W 604's extension only goes into the 40s.  My HT3s go well down into the upper 20s.  The HT3 is truly wonderful and has the added benefit of being able to be built by just about anyone.  The new kits with pre-fab cabinets is an added step of simplicity for those without a tablesaw and router.  The front baffle that came with my HT3 was exquisite.  (I made my own, mine are all baltic birch ply)
Another thing that is cool here is you can totally customize your speaker with any veneer you wish to use.  You can match your furniture easily this way.  I went with walnut on mine and I think it looks better than anything B&W offers.
The HT3 will be a great speaker for you, I have heard both and would choose the HT3 any day of the week and twice on Sunday... oh, wait - it is Sunday!
RawB8figure
« Reply #6 on: 8 Jan 2007, 05:54 am »
I am thinking of building the front baffle as well, so I have one solid piece of MDF on the front, so how did you router out the midrange section. Can you post some pics or connect a link so I can see your work.
audioferret
« Reply #7 on: 8 Jan 2007, 07:22 am »
Well, I merely routed out the space.  It takes a little practice, so start on some scrap MDF or plywood.  Route the driver holes before you assemble the box, not after.  You can get a jasper circle jig from partsexpress.com  - It should provide some pretty nice cuts.
The building process was documented here
http://www.geocities.com/ghaunadaur99/audio/ht3.html
