New OB designs
0 Members and 1 Guest are viewing this topic. Read 6803 times.
Daygloworange
  • www.customconcepts.ca
Re: New OB designs
« Reply #20 on: 28 Feb 2007, 12:19 am »
klh,
If it's the build that is deterring you, we could offer you a kit of pre cut parts to build one of Danny's designs.
That way, the most difficult part, the precise machining of parts, is taken out of the equation.  :green:
Cheers
klh
Re: New OB designs
« Reply #21 on: 28 Feb 2007, 12:31 am »
Are you basically talking about a flat pack? That could be very interesting! I really like the idea of two hybrid OB-7's (four sealed M165X's instead of two M130's in a OB-5 enclosure), a horizontal OB-5 center channel and four O-3's. Doing them as described might be the perfect balance of work/effort and cost. BTW, what are we looking at in terms of cost?
Daygloworange
Re: New OB designs
« Reply #22 on: 28 Feb 2007, 12:36 am »
Yup. No muss, no fuss.
I'll get back to you with a price on it. PM me your Zip code, so I can figure out what the freight to you would be.
Cheers
