0 Members and 1 Guest are viewing this topic. Read 14561 times.
Great analogy,I'll even add to that. I think there is a tier level in audio. Once you reach the high end of audio, the differences start to get smaller. But as you are more and more exposed to the high end, your senses become more acute to the finer nuances. I don't spend as much time as I used to in the studio, my senses wouldn't be as keen, but would sharpen quicker in less time.The wine analogy is a really good one. There are ok wines, then there are good wines. Then there are great wines. But there are differences even with great wines, they don't all taste the same. It doesn't make one better than the other because of the differences. Interestingly, prices are not necessarily indicative of quality in wines, and it appears, in audio as well.Cheers
Quote from: LightFire on 4 Jan 2007, 04:29 am....I know in some circumstances is quite difficult to implement those tests (but in the power cord case it should be quite easy).... Quite easy? Do tell. Please show me a such switching schema, sbt is fine, that would allow non interrupted comparisons. We wouldn't want to corrupt the validity of the test by having to rely upon aural memory beyond 5 seconds now, would we? So your 'easy' mechanism allows you to switch power cords on a cd player while a track is playing, or paused and then within a few seconds, continued?Have you ever actually implemented any such switching mechanisms? Have you actually participated in any sort of blind testing? Or is all this palaver a repeat of what you've read on other boards?Talk is cheap.TIA,Paul
If a quick switch is necessary in ABX that would be necessary in a "non-blind" test as well!!
Quote from: LightFire on 9 Jan 2007, 07:36 pmIf a quick switch is necessary in ABX that would be necessary in a "non-blind" test as well!!Exactly!!! (I think?) The problem with any of the discussions as to the validity of any subjective comparative experiment is that -1. You and other doctrinaire objectivists will inevitably respond - its not a valid test because.....2. Even you and other objectivists can't figure out how to switch the device under test (DUT), to make the test valid for even a SBT, let alone DBT or ABx.Now if you and your compatriots can't figure out how to switch where there are no lapses that would compromise the evaluation and no added intermediation in the path, how do you expect us misbegotten, addlebrained subjectivists to do so? So you suggest SBT as an alternative? Thats not going to preclude you from calling the test invalid due to the time lapse between comparisons.The ONLY component for which its straightforward to configure a valid switching device would be power conditioners, but if, and only if, one has access to those conditioners at the 'wire' level.So the net result is that your camp simply conducts thought experiments based on, IMO, questionable tautologies and make silly 'post hoc ergo propter hoc' conclusions. At least us wrongheaded objectivists make an attempt at gathering empirical data.This is specifically why such discussions ABOUT DBT, ABx, etc... are banned in the Lab Circle, its not that I don't believe in it, its that there in no point in discussing it with anybody that doesn't have first hand experience and knowledge. I and everyone else has heard it all before. I also believe this is why the Moderators don't want these discussions, as absolutely no point is served. If you'd like to start a thread in the Lab Circle about how to go about implementing switching devices for subjective/objective comparisons/measurements, that would be great!FWIW,Paul
All we as objectivists want is a properly controlled blind test
Quote from: Occam on 9 Jan 2007, 08:40 pmQuote from: LightFire on 9 Jan 2007, 07:36 pmIf a quick switch is necessary in ABX that would be necessary in a "non-blind" test as well!!Exactly!!! (I think?) The problem with any of the discussions as to the validity of any subjective comparative experiment is that -1. You and other doctrinaire objectivists will inevitably respond - its not a valid test because.....2. Even you and other objectivists can't figure out how to switch the device under test (DUT), to make the test valid for even a SBT, let alone DBT or ABx.Now if you and your compatriots can't figure out how to switch where there are no lapses that would compromise the evaluation and no added intermediation in the path, how do you expect us misbegotten, addlebrained subjectivists to do so? So you suggest SBT as an alternative? Thats not going to preclude you from calling the test invalid due to the time lapse between comparisons.The ONLY component for which its straightforward to configure a valid switching device would be power conditioners, but if, and only if, one has access to those conditioners at the 'wire' level.So the net result is that your camp simply conducts thought experiments based on, IMO, questionable tautologies and make silly 'post hoc ergo propter hoc' conclusions. At least us wrongheaded objectivists make an attempt at gathering empirical data.This is specifically why such discussions ABOUT DBT, ABx, etc... are banned in the Lab Circle, its not that I don't believe in it, its that there in no point in discussing it with anybody that doesn't have first hand experience and knowledge. I and everyone else has heard it all before. I also believe this is why the Moderators don't want these discussions, as absolutely no point is served. If you'd like to start a thread in the Lab Circle about how to go about implementing switching devices for subjective/objective comparisons/measurements, that would be great!FWIW,PaulGreat Post! Anytime some of these folks who demand these tests would like to pay us for our time in developing one, and setting up the test, would be very, very, very, APPRECIATED! d.b.
... The primary reason is most likely expectation. You expect to hear a difference, so you do.
I am not demanding anybody to run ABX tests.
Did you ABX this?Otherwise it doesn't count.If you did it is a major breaktrough!!! You may be up for a Nobel Prize!
It seems like the believers, as usual, are twisting things around in an attempt to support your beliefs. As objectivists we say without an immediate switching done blindly, YOU (the believers) can't know if the differences you hear are real or only perceived, because audio memory is short and unreliable. We don't require the immediate switching. We want immediate switching so you can hear for yourself that there is no difference, since that is our belief, and then the matter will be settled. Without the immediate switching YOU will likely not be satisfied. For us to be satisfied that there is such a difference as you believe, we don't care how long you listen or how long it takes to switch. All we as objectivists want is a properly controlled blind test where the different cables are identified with statistical reliability. Without valid results, claiming that power cables definitely make a difference is without foundation. We even believe that you hear differences. What you as believers fail to take into accept is that there are a number of valid, scientifically explainable reasons that you hear a difference when, in fact, there is no actual difference. The primary reason is most likely expectation. You expect to hear a difference, so you do.
...What does your third person do? One listens, one switches, 3rd does what?...
Quote from: Marbles on 10 Jan 2007, 01:52 am...What does your third person do? One listens, one switches, 3rd does what?...Passes the beer!
