0 Members and 1 Guest are viewing this topic. Read 11233 times.
Wow, given that those aren't large tubes, and their sizes, and the fact only 2 of them were stuffed, a 10 db reduction is remarkable.
Thanks for the kinds words, guys. More thanks are owed to kj, who actually plunked down the cash for the experiment based on some rather thin comments on my part - not to mention that he did all of the moving and thus bore the fiberglass induced itching! We'll see if Art's more extensive experiment gives us a clearer path forward.One other comment... I'm not sure how much pressure the self adhesive strip on FSK can take. It might be worth bonding the FSK seam in a stronger manner if you plan to stuff the tube with a lot of fiberglass. Liquid nails along the fiberglass edge of the seam may help, although it would be a bit awkward without someone else to help.
but hey, kudos to the guy who shows up with the microphone and software....
One other note, if you smoke (as I do) the giant cigarette look is oddly appealing....
Another option is to use progressively smaller tubes inside with layers of batting or insulation around them. This provides not only solid absorbtion but also forces the wave to transfer through different mediums. This creates progressive high pressure/low pressure areas. As the wave moves out of a dense medium, it loses pressure then it hits the more dense material and creates higher pressure - and to a certain extent - a mini backwave to help cancel that coming in the lighter material.
