...For the few that are still not be completely taken in, it is not possible that the last few feet of power wire can have any impact compared to hundreds of miles of power company wire and transformers and switches and contactors and junctions, the home wall wiring, circuit breakers, and junctions, where the audio gear is already protected by actual circuitry, not just wire, in the form of regulated power supplies that reject power disturbances, and built-in power filters and surge suppressors that soak up transients and noise. It's simply not possible, like filling your tank with gasoline from a blue hose instead of a black one can not make your car run better. A person can easily be convinced that the blue hose has this effect, but that doesn't alter the reality. Let's say it is possible, but modern physics can not explain it. Where's the neutral data from double blind A/B testing? We're not going to find any, because this is precisely the type of spurious effect that proves that one can seem to hear things that are not real. Recognizing the truth of this type of effect is how you maintain a sense that your ears are fallible. This is how one maintains a sense of reality and guards against exploitation.
Thank you for resurrecting this thread anyway. Now back to our scheduled program...I realized I should have given a rating update based on my later comments so here goes the revised order of (yes, MY personal) preference with comments from my pad of notes:1) Bolder Summit (either one) - clear window, fast edges, very articulate bass2) Harmonix Studio Master X-DC - more transparent, up front, and cleaner bass than Z1 which is good for me. Goes just too far over the edge of rightness (edgy) compared to the Bolder.3) Black Sand Violet Z1 - Good cord at half the price of the others. I found it actually fares better on my monoblocks than the front end for some reason.4) MAC Delta - very close to Z1, almost a tie, but more laid back. very smooth5) Cardas GR (simply slower and thick)The Black Sand Silver Rev MK V's are incoming any day now, so I'll do my best to fit it in the rankings. Unfortunately, I don't have the Summit anymore but I'll give it a shot from my memory and comparing to the Harmonix.Tom
Quote from: TomS on 2 Mar 2007, 01:21 amThank you for resurrecting this thread anyway. Now back to our scheduled program...I realized I should have given a rating update based on my later comments so here goes the revised order of (yes, MY personal) preference with comments from my pad of notes:1) Bolder Summit (either one) - clear window, fast edges, very articulate bass2) Harmonix Studio Master X-DC - more transparent, up front, and cleaner bass than Z1 which is good for me. Goes just too far over the edge of rightness (edgy) compared to the Bolder.3) Black Sand Violet Z1 - Good cord at half the price of the others. I found it actually fares better on my monoblocks than the front end for some reason.4) MAC Delta - very close to Z1, almost a tie, but more laid back. very smooth5) Cardas GR (simply slower and thick)The Black Sand Silver Rev MK V's are incoming any day now, so I'll do my best to fit it in the rankings. Unfortunately, I don't have the Summit anymore but I'll give it a shot from my memory and comparing to the Harmonix.TomTom,I will be comparing Wayne's power cords with the Black Sand Silver Max MK V and Violet Z2. I'll try and get some listening in this weekend, after I get back from Cork.George
