Marantz SA15S1 SACD player question..
0 Members and 1 Guest are viewing this topic. Read 1972 times.
es347
  • ..I've got my eye on you...which one you say?
« on: 28 Dec 2006, 05:36 pm »
I have a Marantz SA15S1 player I bought earlier this year and it seems to have a problem.  When a disc is loaded and the drawer is closed, as the speed ramps up there is a noticeable vibration that either continues or stops when top RPM is reached.  Sometimes opening and closing the drawer stops it but more often than not, it continues.  I read somewhere that the spindle on the player was either over sized or undersized thereby causing the resonance.  Has anyone had a similar experience and if so, what is the solution?  Does Marantz stand behind a problem like this?  It is very annoying and pretty much inexcusable for a player of this level.
Thanks in advance for your input.
Gavin Hadley
ps...we are in the midst of building a new house so my Marantz is in storage at the local mover's warehouse along with just about everything else I own and enjoy.  I won't have access to the piece until May-June 07 so would assume Marantz would still honor its 3 yr. warranty at that time.  How well do they stand behind their goods?  (side note:  I did a spellcheck and it suggested changing "Marantz" to "marinate"...you may want to let that soak in...)
Digi-G
Re: Marantz SA15S1 SACD player question..
« Reply #1 on: 3 Jan 2007, 03:57 pm »
Well, I don't know any specifics about the problem, but I would think Marantz would definitely fix it under warranty, esp. if it's a higher-end unit.
As for waiting 3-4 months before doing anything... well, I wouldn't wait at all if possible.  Besides, if you have to ship it somewhere for 6 weeks now would be the time to do so, not when you're ready to listen.
Sonny
« Reply #2 on: 13 Sep 2007, 06:19 pm »
Any news on this Marantz SA15?  Does it still have the problem? have you fixed it???
