0 Members and 1 Guest are viewing this topic. Read 10837 times.
They are nuts and should commit hari kari (spelling?) emmediately. Now you got the cart. Don't play it like this on good records. Find a vinyl freak/tweaker. Can't be that hard!
I just stumbled on this, might be useful?http://www.audiophilia.com/features/cartridge_setup.htm
"Ah yes, thank you! Come to think of it, I should mention why I'm doing this in the first place - it's actually so that I can transfer LPs to CDs!"All the more reason Justin to do it right the first time! it's very time consuming. How's it coming?
If I were you and you really want to continue this adventure, I would try and find a used mc phono stage there.
It's supposed to be fun Sounds like you are having your own calvary...The noise is indeed probably coming from the phono section of the amp. Maybe nothing more than a loose connection. Open it up and have a look if the rca connection is tight, if you can see anything obviously wrong. Still haven't uneartheda nice Jap. tt geek???
woodlandjustin: I am assuming that the noise you hear is w/o a record playing. Does this noise increase as you turn up the gain knob? I'm guessing but it is probably explained by the fact that phono stages provide a huge amount of gain. Typically, for MC, the gain will be over 50 dB. Any noise will also be magnified enormously as well. A CD or a DVD player in comparison, usually outputs a much stronger signal, usually around 2 volt, whereas an MC cart is rated in mV and must rely on a gain stage or several gain stages for the system to play loud enough that the music has proper dynamics. A good phono stage accomplishes its function w/o an objectionable amount of noise.
