Other Stuff
Archived Circles
General Archive
Cable advise needed
Cable advise needed
0 Members and 1 Guest are viewing this topic. Read 1530 times.
Hallet
Cable advise needed
27 Dec 2006, 03:57 am »
Hello i need some help deciding witch speaker cables to get what will sound the best with my gear
Bryston 4b-sst amp
Bryston sp-2
classe delta cd
velodyne dd 12 sub
all this gear is new somthing thats not bright moor neutral
i think i will need to tone things down some with the Bryston amp.
the speaker cables will need to be about 15' long
somthing that reasonable in price.
thanks guys .
tvad4
Re: Cable advise needed
27 Dec 2006, 04:00 am »
Use the wire Bryston recommends/sells.
jdaly
Reply #2 on:
27 Dec 2006, 06:41 am »
What are you using now? Don't think you have to spend a lot to get a lot. For a steal, check out those anti-cables. But I agree with the previous post, see what they recommend and go from there.
The elephant normally IS the room
Reply #3 on:
27 Dec 2006, 10:34 am »
All your audio cabling needs (speaker, interconnect, digital, power) that are reasonably priced and provide decent sound quality (by snobby audiophile standards) can be found at Signal Cables, Element Cables, and Blue Jean Cables.
halo
Reply #4 on:
27 Dec 2006, 03:17 pm »
I'd like to 2nd the Signal Cable option. Zebra cables and Cobalt Cables are other choices also.
arthurs
Volunteer
Reply #5 on:
27 Dec 2006, 03:28 pm »
all excellent suggestions, beginning with finding out what Bryston recommends.
I'd also add Gregg Straley's Reality cables to your list. Plenty of threads here about their quality and caliber...
Hallet
Reply #6 on:
4 Jan 2007, 06:06 am »
Thanks guys i talked to Bryston & they recommended there cable they said
if there was any difference it would be very minimal same with the interconnects.
so do you think i should try them out. thanks for all your help.
Other Stuff
Archived Circles
General Archive
Cable advise needed
