0 Members and 1 Guest are viewing this topic. Read 12623 times.
Steve Eddy, you are hilarious! I almost fell off my chair laughing about your comment and picture.
I've never seen donkey dicks, and now you are making me even more glad about that!
George is a really cool guy. He let me bring my speakers and amp to audition the pre amps. How many guys will let you do that?
Sorry, I missed your suggestion about the Burson. I've heard about it before. I was just reading about it. Sounds interesting. This stuff is way over my head though. It talks about maintaining the same voltage, but lowering the impedance.
See, I just learned something new. Ok, now I'm curious as well. Steve Eddy. what are your thoughts on applying this Burson thing to better drive an amps input? ( considering the modded SB's output of 1.1 volts, not sure of the impedance though)
Or what about that TVC thing I keep seeing posts about on AC? Man, there's like 64 pages on that thread!
And yes, I'm starting to feel neurotic about all of this, I've reached that slippery slope thing, and I guess I've fallen off.
What exactly would the net effect of the Burson be? Would it up the voltage to the amp input?
Quote from: NewBuyer on 29 Dec 2006, 04:27 amDaygloworange, and especially Steve Eddy,What do you think of the idea, of using the chain SB3 -> Burson Buffer -> Endler Attenuators -> Amp.It seems this would give the desired voltage/current/gain boost from the SB3, and easily drive the signal through the amp - in fact you could use several Y-adapters with the Burson unit with no performance drop.Your thoughts please?That'd be fine, though unless you're intending to put Burson Buffer right at the output of the SB3 and the Endler Attenuators right at the input of the amp, I'd recommend putting the Endler Attenuators right at the input of the Burson Buffer.se
...The Burson thing appears to be a DIY module, correct? And it's not passive, right?...
Could you please speculate: Which location for the Endler Attenuators (amp inputs, or Burson Buffer inputs) do you think is preferable, and why? The Endler Attenuators are 4k shunt-type, so something like the Burson Buffer can drive a signal through these Endlers effortlessly, and the system noise floor is greatly improved too when using the Endlers directly on the amp inputs (no cable capacitance issues to worry about either). However, the config you suggest would allow attenuation of all (possibly y-adapted) output signals from the Buffer equally, thus eliminating any need to dial-down the subwoofer for level matching - but the source would also then be trying to drive the signal through the 4k attenuators, instead of the much higher amp/preamp input impedance.
Ok, here I was thinking that after one or two posts I'd be off on my way.......As someone who doesn't have strong fundamental knowledge of EE, I find this stuff makes my head spin, and gets me frustrated. The deeper I delve into it, the more I realize my limited understanding of it.
As it stands now. I'm not sure which is the way I'd like to go, There seems to be a number of alternatives to overcome the modded SB 3's low output voltage. I'm not sure I'm understanding all the passive pre-amp stuff very well though. And all the impedance and capacitance stuff too. An increase of 6 db's of voltage? I didn't know you could increase voltage by db's. Or is it increasing the voltage (in volts) with the net effect being a 6db increase in output of a device? Isn't 6db what our hearing perceives as twice as loud?
The Burson Buffer I refer to is a plug-and-play component. Here's a link...
10dB corresponds to a ten fold increase in power. So all else being equal, 10 watts of power sounds about twice as loud as 1 watt of power. 100 watts of power sounds about twice as loud as 10 watts of power. 1,000 watts of power sounds about twice as loud as 100 watts of power, and so on.
...That leaves you with two other possibilities. Putting the attenuator right at the amplifier input or at the input of the buffer. This way, in both instances, the cable capacitance is being driven by the low output impedance of the buffer...
Hi Steve, thanks but what you've just said is already contemplated in my last post. I was wondering which of these specific two location options for the Endlers (mounted on amp inputs, or mounted on Buffer inputs), you would speculate to be preferable? (I listed some pros/cons of each in my last post too)
...you want to control volume for all of the other inputs, then putting the attenuator at the front of the Burson would be preferable. If you're just going to be driving a single input, then I would put them at the amplifier inputs as this would give the best signal-to-noise performance...
Thanks Steve Eddy, but note I already said all this in my same previous post too. I was asking you if you had anything else to add to these considerations.
Steve I thought you said you were giving up crack for the New Year? (Just teasin ya)
Hope you and everyone else has a Happy New Year!
