0 Members and 1 Guest are viewing this topic. Read 5060 times.
Wayne built me a U2 PS with copper Bybee and the Summit DC cable a few weeks ago. I've been burning it in for about 500 hours now. Its amazing how those 500 hrs. transformed this PS. When I first got it, I warmed it up for about 1hr and then compared it to my MauiMods Ref. - it was immediately apparent that the brand new U2 was at a much higher level sonically than the Maui. I've said this before but the lushness and the feeling that I just opened a foggy window onto the music was overwhelming!!! I listened to Kimmie Rhodes and Willie Nelson - Picture in a Frame. It actually brought a tear to my eye I immediately went back to the Maui and found it somewhat dead sounding in comparison - veiled and unemotional. Its funny how you think something sounds awesome until you compare it to something better! During the 500 hrs. the sound went bad-good-bad-good several times. I was aware that this would happen due to the caps forming in... in the last 300-400 hrs I haven't noticed anymore changes and the sound remain EXCELLENT! I've made a couple other cable changes during this breakin but the PS still stands out as being outstanding! At the time Wayne was building my PS I sent him my SB2 that he modded about 1 year ago. Wayne graciously upgraded both the digital and analog to current spec free of charge! Thats excellent customer service from Wayne - as usual I'm using the SB2 digital out via a Purist Audio Design digital cable into a MHDT Paradisea DAC(Bendix Redbank tube). I'm getting the best sound from the SB ever. Very detailed, lush, transparent, super deep/defined bass, not fatiguing etc... You get the point. Very well done Wayne ThanksTony
Mr. TDangeloIf I am reading you right, you are saying that the improvements you are hearing - less foggy, dead, etc. are due to the Bolder Ultimate PS and Summit Cable (with SB2 digital out to dac)?If so, that is high praise for just changing a power supply!Bill
the Ultimate II was about 2 times the price - but I think its definitely worth it I should have stated the price difference in my mini review Tony
exactly. I always find that once I insert a component and then remove it, there is where I hear a greater difference - be it good or bad. The PS on the SB makes a huge difference to my ears.TonyQuote from: mr_bill on 24 Dec 2006, 04:25 pmMr. TDangeloIf I am reading you right, you are saying that the improvements you are hearing - less foggy, dead, etc. are due to the Bolder Ultimate PS and Summit Cable (with SB2 digital out to dac)?If so, that is high praise for just changing a power supply!Bill
How about a detailed comparison between Paradisea vs. analogue output of SB2/U2?
I wish I could ;( The modded SB2's output voltage isn't enough to get my amps loud at all ;( My Jolida's need 2.35V for 200wpc - the modded SB2 only puts out 1.1V if I remember right? I may try it again this weekend.TonyQuote from: Jon L on 24 Dec 2006, 10:07 pmHow about a detailed comparison between Paradisea vs. analogue output of SB2/U2?
But does your SB2 analog out has all the goodies???Quote from: tdangelo on 24 Dec 2006, 10:32 pmI wish I could ;( The modded SB2's output voltage isn't enough to get my amps loud at all ;( My Jolida's need 2.35V for 200wpc - the modded SB2 only puts out 1.1V if I remember right? I may try it again this weekend.TonyQuote from: Jon L on 24 Dec 2006, 10:07 pmHow about a detailed comparison between Paradisea vs. analogue output of SB2/U2?
just the normal analog upgrades that Wayne does - no Bybees. It wouldn't really matter anyways - I don't get enough volume. I'm guessing but I don't think I even get 83-86db....Quote from: 95bcwh on 24 Dec 2006, 11:47 pmBut does your SB2 analog out has all the goodies???Quote from: tdangelo on 24 Dec 2006, 10:32 pmI wish I could ;( The modded SB2's output voltage isn't enough to get my amps loud at all ;( My Jolida's need 2.35V for 200wpc - the modded SB2 only puts out 1.1V if I remember right? I may try it again this weekend.TonyGeorge (Zybar), if you're out there - don't you run your SB2 directly into your Moscode amp? Do you get enough volume or does the low output volume of the SB2 negate running straight into an amp?Just curious, in case I ever try to go that route.Bill
Hi all,Does it benefits for the digital out only with the Ultimate PS ? Or it most benfits analog out ?Thanks.
