AV-3 vs OB-5 in HT setup - Opinions?
0 Members and 1 Guest are viewing this topic. Read 5258 times.
Danny Richie
    • http://www.gr-research.com
Re: AV-3 vs OB-5 in HT setup - Opinions?
« Reply #20 on: 28 Dec 2006, 04:11 pm »
There are two things that I don't like about front porting. One is the possibility of port noise when playing them hard. This is not a factor with the A/V-3 though as it has a large opening for the transmission line.
Next is that you get what you get. In other words less flexibility. With the port in the rear you can vary the distance to the back wall and vary the gain from the port a little bit. When it is in the front you don't have this flexibility.
In the sub 200Hz range the power handling of the A/V-3 and the OB-5 are the same.
mnapuran
« Reply #21 on: 29 Dec 2006, 04:01 am »
Thanks Danny... make complete sense.   Back to original question though... Do you recommend the AV3 or the OB5 more in an HT config (mainly), and only being able to be around 10-14" off the back wall?
