Introducing the V3
DMurphy
    • SalkSound
Re: Introducing the V3
« Reply #20 on: 23 Dec 2006, 06:24 pm »
I certainly appreciate the vote of confidence.  I can't think of a better person to give initial feedback. And, of course, if there's anything you don't like I'm sure we can fix it.  Thanks!
Toka
« Reply #21 on: 5 Jan 2007, 09:19 pm »
Agreed on the feedback...please keep us posted Frank!
Big Red Machine
« Reply #22 on: 23 Jan 2007, 11:15 am »
BTW folks, Jim's V3's made their way into my HT and the clarity of sound is something I have never experienced.  Even in phantom mode w/o a center the imaging is incredible.
Next up is to try a Salk center channel with similar voicing. :thumb:
Toka
« Reply #23 on: 23 Jan 2007, 03:20 pm »
Hey Big Red...how did the V3's stack up against the HT3's? And I liked the audio rack you had in pic #59 (I think)...was that a custom job?
Big Red Machine
« Reply #24 on: 23 Jan 2007, 06:51 pm »
I never dragged the V3's into the 2 channel room.  They have scary imaging, are very efficient, and just are so clean.  I am leaning toward these in my HT.  You should hear the center image w/o a center channel speaker in surround modes!
Rack is plywood with SST style Formica and solid Black Walnut shelves from northern Michigan.  The shelves cost me more than the rest of it including those funky wheels I bought.  Took me a couple of weeks with nights and weekends to fabricate.
bkatbamna
« Reply #25 on: 23 Jan 2007, 10:17 pm »
Good to hear about the V3s.  I've ordered mine and am waiting for the veneer pics so that I can pick the finish of mine.  Once I get them, I'll post on here too.
zybar
« Reply #26 on: 23 Jan 2007, 11:26 pm »
What is the efficiency of the V3 speakers?
George
BradJudy
« Reply #27 on: 24 Jan 2007, 12:01 am »
Model  V-series V3
(3-way floor-standing)
Design    WMT 3-way
Drivers    (1) LCY pure ribbon tweeter, (1) Visaton TI 100 midrange and (1) Visaton A800 woofer
Response    35Hz - 25KHz (+/- 1 1/2db)
                    32Hz - 60KHz (+/-3db)
Sensitivity (dB/2.83v/1M)      86db
Impedance (nominal)    8 ohms
Recommended Amplification    30 - 150 tube watts/80 -250 solid state watts
Box Alignment    sealed midrange tweeter section; ported woofer section
Dimensions (HWD)    floor standing: 43" H x 10.5" W x 14" D (not including optional plinth)
DMurphy
    • SalkSound
« Reply #28 on: 24 Jan 2007, 12:48 am »
That's a very conservative rating.  Commercial sensitivity ratings generally are made at 1 kHz, were most speaker systems have a baffle step peak or a cone-edge resonance. The Visaton is actually down a little at 1 K, so the effective sensitivity, in comparison to other commercial speakers, may be more like 88 dB.  It's considerably more sensitive than the HT3, which sacrifices some sensitivity for the outstanding bass reach and clarity of the TC1 woofer.
LadyDog
« Reply #29 on: 6 Feb 2007, 01:47 pm »
Frank,
Any further thoughts on how the V3 stacks up to the HT3.  Thanks for your time.
Jeff
avahifi
    • http://www.avahifi.com
« Reply #30 on: 6 Feb 2007, 07:40 pm »
I don't have mine yet.  Jim is doing something a bit different with the finish as a careful experiment.  I will let you know.
Frank
