I am looking for an inexpensive 6 ch converter.
0 Members and 1 Guest are viewing this topic. Read 1123 times.
WOR Radio
    • Main Website
« on: 19 Dec 2006, 08:15 pm »
hello, first post.
I have a computer that has the 5.1 fiber and coax outputs on it for playing dvd's.
What I am looking for is an inexpensive converter with 6 audio outs (L/R LR/RR/C/SW so I can use this with speakers in another room. My analog runs are not going to be long at all, just through the wall to a 6 channel amp and speakers.
The outputs I have now are on the back of the computer using cheesy 1/8 inch jacks. I want this converter to have RCA's.
the computer is set up to run its own analog conversion + the dig out stream. Just want to power up the other room.
Also, I have a DVD player with just 2 audio outputs. It also has the coax/fiber out. I could use it as well.
What I am trying to avoid is having to buy a 6 channel receiver. They are cheap enough I just don't want one.
And another thing:
I noticed that dvd players that have the 6 analog jacks are not much more expensive. This leads me to believe that i should be able to convert rather inexpensively.
Thanks for any answers.
Looking for 100 to 150 price point.
Russtafarian
  • Typical reaction to the music I play
Re: I am looking for an inexpensive 6 ch converter.
« Reply #1 on: 20 Dec 2006, 10:41 pm »
Last month I was looking for the same thing and found that this is the only game in town at that price point.  Creative DDTS100
http://us.creative.com/products/product.asp?category=4&subcategory=136&product=9468&WT.cg_n=Campaigns&WT.mc_id=2558
Russ
WOR Radio
    • Main Website
« Reply #2 on: 21 Dec 2006, 03:49 am »
Thank you Russ, have not seen that!!
I am surprised that this type of device is not getting any traction with the higher fidelity users. Without a receiver, how else you going to do it?
This looks like an area that has been painfully neglected in audio.
Russtafarian
« Reply #3 on: 21 Dec 2006, 07:01 pm »
I've had mine for about a month.  The box is bigger than I expected but it functions as advertized and decodes DD and DTS just fine.  When I listen to it as a stereo DAC, it sounds pretty pedestrian.  But maybe with a few mods...
Note that because this is designed primarily for computer speaker use, the 5.1 outputs are minijacks not RCAs.  Not a big deal in my book.  Lots of minijack to RCA cables out there that will work.
Russ
