0 Members and 1 Guest are viewing this topic. Read 11752 times.
Are the 3 power supplies SMPS or linear? Thanks!
Take a look at the plot http://www.nuforce.com/plots_p9.htmNo other preamp in the world can handle a 125KHz square wave input as clean as P9.
Jason, How much gain does this unit offer ?
Quote from: nuforce-jason on 25 Dec 2006, 01:25 amTake a look at the plot http://www.nuforce.com/plots_p9.htmNo other preamp in the world can handle a 125KHz square wave input as clean as P9. Why do you want to pass 125k square waves, ie what does the output of your companion power amp look like with realistic loads at full power if you do? thankssteve
Quote from: eico1 on 25 Dec 2006, 03:48 amQuote from: nuforce-jason on 25 Dec 2006, 01:25 amTake a look at the plot http://www.nuforce.com/plots_p9.htmNo other preamp in the world can handle a 125KHz square wave input as clean as P9. Why do you want to pass 125k square waves, ie what does the output of your companion power amp look like with realistic loads at full power if you do? thankssteveThat's what it takes to preserve music's transients.
