0 Members and 1 Guest are viewing this topic. Read 12115 times.
Why do you think you "shouldn't be"? One thing that isn't clear to me on Ethan's units is the fiberglass on the rear. Are the wells closed, with the fiberglass behind? We do not use fiberglass unfaced in any direction. The emission of fibers into the air you breathe is definitely a problem. The lung association has studies on that. I am glad you are enjoying the sound of diffusion..It is very hard to describe to people, but when they hear it, they always smile!
When cost is not a factor, the best way to treat a corner fully with RealTraps products is a MondoTrap straddling the corner, about halfway up between the floor and ceiling, and Tri-Corner traps above and below. The reason this is better - but again, when using RealTraps products - is it gives the most broadband absorption.--Ethan
The question came to mind because like Zybar I also have rather large crown moldings which as I understand detract from the effectiveness of the Tri-Traps. Also like Zybar I am not going to cut into the moldings. So two mondos; one a couple of inches off the floor, the second suspended a couple of inches down from from the ceiling with a gap of two inches or so between the top of one and the bottom of the other might be nearly as good as one mondo and two Tri-Traps?
Why don't you use acoustical cotton instead of rockwool or fiberglass?http://www.ecowise.com/green/insul/index.shtmlRaj
Goob,> Could Ethan or another mfgr/vendor comment on the use of real wool rather than fiberglass??? <There's nothing wrong with fiberglass, and certainly not from the perspective of a consumer of commercials traps. Real wool is likely okay, but I assume it will sag and be lumpy etc much like mineral wool. Owens-Corning 705 is tough to beat for acoustic performance and also for its physical properties.--Ethan
