0 Members and 1 Guest are viewing this topic. Read 23293 times.
Sounds great Brian, thanks for the offer and will keep my ears open to it!!!! .......it all went very well...they sold out the last 4 performances, inc. standing room! There will be more performances in the spring, including one that will be televised live in selected movie theaters around the country and overseas, somewhat like a live rock concert. You pay one price, prb around $15-$20 and you watch it on a large screen with surround sound...hey Brian..they should use your speakers!! Not sure about Verona at this point, but will keep you posted!Happy Holidays to all!
Brian, I have a question. Why two different choices for Subs on the V60's? I know you explained the VLA has about half the distortion and moves more air but there must be more to it than that? What circumstances would dictate one over the other? Would two VSS subs be a better choice than one VLA? Does the VSS excite the floor more than the VLA? Would the room dictate which one would be a better choice? Please explain I'm at a loss. Thanks!
John, price is somewhat of an issue so the choice is narrowed between a single VLA or two VSS subs. Can you tell me where a single VLA should be placed in respect to the main V60's? Can either the single VLA or the pair of VSS's be placed behind the V60's? What is optimum? Thanks!
I may have missed it but are there pictures and/or specifications as to dimensions for the VSS and VLA posted anywhere. I think I read 6 feet tall for the VLA and a little smaller than the original sub for the VSS. I'm also anxious to see pictures of a complete setup with v60 and subs and a listening report. Tom
I think the upgrade route would go better for you with the RM/X. CDWG is available.
John, if using two VSS subs and the V60's are ten feet apart can the subs be placed between the V60's to good effect? I can not place the VLA in between the V60's because a big screen TV is there but I can the VSS pair because they are low enough. I take it by your ITU formation you do not reccommend placing the subs behind the main speakers? Thanks!
What are the VSS and VLA? Was there a thread discussing them?
