0 Members and 1 Guest are viewing this topic. Read 37152 times.
I don't know how to do a poll. Can anybody help out on that?Cheers
Anybody have a killer pre amp that they want to bring along?
Here a few more additions that will probably be attending:Graaf GM50 (tube integrated)Flying Mole DAD-M100 mono blocs (digital amp)Electrohome PA-100 MK-1's. (KT-66)
Even better would be a direct source with volume control - i.e. high-end CDP. I think a pre would mislead as you'd essentially be comparing a pre/amp combo (in addition to the CDP of course). But I suppose its all relative if the same source and pre are used each time.
And one more thing... you need to accomodate both balanced and un-balanced connections in the choice of pre or cdp. Not that it matters which one but it would matter if you had to change either the pre or cdp to accomodate a limited input amp.
Quote from: Daygloworange on 24 Dec 2006, 10:18 pmI don't know how to do a poll. Can anybody help out on that?CheersUsually only Mod's can create polls. Spirit?
QuoteEven better would be a direct source with volume control - i.e. high-end CDP. I think a pre would mislead as you'd essentially be comparing a pre/amp combo (in addition to the CDP of course). But I suppose its all relative if the same source and pre are used each time.That's why I wanted to run the modded SB 3 directly into the amps. No pre-amp. The only buggaboo is that the modded SB 3 only puts out 1.1 volts. My amp says it'll take a 1.3 volt input, and it sounds OK with the modded SB 3, but it's not as loud as before with my CDP and pre-amp combo that I had before.
