Jolida Tuner -- Need help
0 Members and 1 Guest are viewing this topic. Read 1050 times.
Mountain-ear
« on: 12 Dec 2006, 03:08 am »
Recently purchased a Jolida TU-9608B tuner (similar to the 401A).  The FM is fine, but the AM section increments by 9kHz instead of the normal 10kHz.  I think the 9kHz steps are used in Europe, but it doesn't do me much good here.  Anyone know if this is something that can be easily changed?  I took a look inside and out and didn't see anything that looked to me like a switch that could be set or a jumper that could be moved.
Scott F.
Re: Jolida Tuner -- Need help
« Reply #1 on: 12 Dec 2006, 03:40 am »
Unfortunately, I've talked to Mike Allen at Jolida about this one before. There is no switch on the AM band to make it US compatible. the only thing to do if you listen to AM is get a new model which conforms to our AM band standards.
