Frykleaner with Power Cords and MC Stepups?
0 Members and 1 Guest are viewing this topic. Read 1760 times.
jcmjrt
« on: 11 Dec 2006, 02:41 am »
Can the Frykleaner be used to break-in power cords? If so, how do you make the connections?
Also, I was thinking about getting some transformers (I'm not sure which ones yet - Lundahl, Jensen, Tribute??) and was wondering if they can be broken in with the frykleaner? I'm guessing that one would do that with rca cables going to a completed step-up input and then rca cables out the output and back to the frykleaner. Amorphous cores have a particular rep of taking forever to break in so a little help would be good.
amandarae
Re: Frykleaner with Power Cords and MC Stepups?
« Reply #1 on: 11 Dec 2006, 05:47 am »
Hi JC,
Small world ain't it?
Exactly what I did with the two SUT's that I have (Tribute and Cinemag) at present.  Added bonus is you can burn in interconnects, if you also made a pair, simultaneously with this method.
For power cords, the FryKleaner will work but man, you will wait for a very long time I suppose.  The signal from the unit is very small.   If it was me, I will make a set up with a 100 watt bulb where its holder is hardwired to an IEC and voila, an instant power cord "burn in" machine.  Better yet, if you can figure out how to use the cords for your home vacuum cleaner.  Not only that you will burn in the cords, your house will be sparkling clean and dust free in the process. :D
Okay, I am only kidding about the vacuum cleaner but the light bulb scenario is promising.
cheers
hagtech
« Reply #2 on: 11 Dec 2006, 07:01 pm »
Yes, you can break in power cords.  The FRY PRO does this.  I'm not sure yet what the optimal arrangement is, but I typically connect a signal to both L and N (different polarities) and ground the E.  Run this with one end open for awhile for voltage mode.  Then short circuit the far end, all three prongs.  This will force a current mode burn (which is more effective).  At this point, I think it would also be best to make polarity of L and N the same, to insure current returns via E.  The 3-wire cord is a bit more difficult than the 2-wire types.
Also, you won't need a 100 watt light bulb.  This is a myth I am trying to dispel.  For break-in of cabling, forget what the ultimate application is.  It does not matter.  We have to break-in the materials and complete the manufacturing process (adding cryo would be good too).  Power cords break in just like phono wire.  Do not mix the application with the burn.
For step-ups, I run them at full output level, not with an iRIAA.  Even more effective if you short the secondary outputs, which forces a magnetization flux in the core.  I use the ESR of the winding as the load.  There are a number of ways to hook up, but I always find the current mode to be best.
jh
jcmjrt
« Reply #3 on: 11 Dec 2006, 08:40 pm »
Hi Amandarae,
Yes, it is a small world. Thanks for the info on the stepups. If I could find someone else to run the vacuum cleaner, I might give that a try. :)
Jim,
You say that the Pro will break in power cords but couldn't I run signal with adapters from the rca jacks on the frykleaner just as you describe below? Thanks for your help.
hagtech
« Reply #4 on: 12 Dec 2006, 04:56 am »
Yes, same thing.  FRYPRO has the same board inside.
vacuum cleaner
Actually, this probably would work quite well.
jh
jcmjrt
« Reply #5 on: 13 Dec 2006, 03:44 am »
Sold!! Looks like it's an awesome product and priced as a total bargain. Thanks.
Just one question....can you help with the vacuum cleaner? :>)
