0 Members and 1 Guest are viewing this topic. Read 27311 times.
Interesting thread, but a lot of speculation and subjective-only comment.
The front part of an H has no effect on the travel distance of either wave front,or using JohnK's terminology, it does nothing to "delay" the rear wave from reachingyour ears, and it obviously doesn't affect the front.
Quote from: Davey on 28 Dec 2006, 04:22 pmInteresting thread, but a lot of speculation and subjective-only comment. Could you post a link to your measurements please? Thanks
Quote from: JohninCR on 28 Dec 2006, 05:04 pmThe front part of an H has no effect on the travel distance of either wave front,or using JohnK's terminology, it does nothing to "delay" the rear wave from reachingyour ears, and it obviously doesn't affect the front.Yes, I understand that. But remember we're talking about more listening and measuring locations than just the "front" where your ears might be located...(at distance "L.") I'm talking about the whole picture. When you "front-think" about the situation from a single point in space it does seem rather simple and all the diagrams make much more sense.By the way, I take real exception to your inference that my measurements have led to incorrect conclusions. My measurements (outdoors/indoors/near/far) have in most cases confirmed the analysis/measurements that SL and John K. have put forward regarding these woofer configurations. Since these two fellas are acknowledged experts in speaker design I assumed that my measurements were valid and probably not incorrect.Cheers,Davey.
I believe the concept of JohnK's negative group delay is an avenue requiring furtherscrutiny, especially when added to John Sheerin's statement that below the 1/4 waveresonance the air in a pipe moves in unison, making the terminus the source. If myunderstanding is correct then this is the cause of the negative GD. It seems intuitivethat an expanding pathway has the potential for reducing or eliminating this effect. I've already found it to, at a minimum, spread or reduce, resonant behavior without damping. Getting rid of the negative GD is important too, because we need the full benefit of propagation delay for the rear wave from the rear of the driver around ourconstruction. Is stuffing the only way to skin this negative GD cat?
I'm looking into other approaches as well, but unfortunately they all have one draw back. Things get physically bigger, something a stuffed U tends to avoid.
Here's something I did about a year ago. I was waiting to do measurements, but it's pertinent here. My approach was to hopefully prevent resonances and create different driver to edge differences around the baffle.I tapered the terminus by 2" and in the end of the shortest panel I cut out a Karlson shaped "V" for an even earlier start of some pressure release.
