Paradisea Problem - Need Assistance Please
0 Members and 1 Guest are viewing this topic. Read 14467 times.
woodsyi
Re: Paradisea Problem - Need Assistance Please
« Reply #60 on: 15 Dec 2006, 04:55 pm »
My WE396A tube should be here today.  :thumb:
Do you have to remove the top cover to swap the tube?
Yes.
F-100
« Reply #61 on: 17 Dec 2006, 07:02 pm »
Thanks, Woodsyi.  :thumb:
Well, I got my WE396A tube in my DAC. Right out of the box, it sounded horribly from top to bottom. After 12 hours of break-in, the sound improved a little bit but still way below par comparing to the stock tube.
How long does it take for the type of tube to break in?
tvad4
« Reply #62 on: 17 Dec 2006, 07:57 pm »
No more than an hour, in my experience. 12 hours is more than enough time to determine if a tube is to one's liking.
echo1
« Reply #63 on: 23 Dec 2006, 07:57 pm »
I am getting the hum/noise also starting at 12:00. I have tried a cheater plug and different sources. Tried the USB out to a PClink transport, a internal sound card with toslink, and toslink out with a Turtle beach audio advantage in a different computer,a laptop.
All have noise/hum at 12:00.
 My amplifier is a Darkvoice and is dead quiet without the Paradesea.
So add one more to the list
Scott F.
« Reply #64 on: 23 Dec 2006, 08:16 pm »
Does your preamp drive your amp into clipping at (or before) 12:00?
If so read this;
http://www.audiocircle.com/index.php?topic=34151.msg307114#msg307114
If you regularly listen with your preamp set above 12:00, then you likely have an issue. If you don't listen with your pre set above 12:00, then it should be a non-issue.
echo1
« Reply #65 on: 23 Dec 2006, 08:37 pm »
 I replaced the stock volume pot in the Darkvoice with an Alps pot which is more linear. So the clipping doesnt start untill about   2 to 4 oclock. I dont listen to it at that volume with headphones, but a speaker system may be different. But 9 to 11 is a normal  level with headphones. 12 to 2 is ear damage area.(depending on how loud the recording was recorded)
« Last Edit: 23 Dec 2006, 09:51 pm by echo1 »
echo1
« Reply #66 on: 23 Dec 2006, 09:25 pm »
Well I just tried another amp. A yamaha reciever and it  hummed also.
« Last Edit: 23 Dec 2006, 09:44 pm by echo1 »
F-100
« Reply #67 on: 24 Dec 2006, 04:54 am »
I was rearranging the DAC in my system and by accidently I found out that the further I move the DAC away from my tube preamp, the hum will go away. But when I move the DAC close to the preamp, the hum become very loud. So now, I have my DAC about 2 feet from the preamp and no hum. Go figure!!!!
« Last Edit: 24 Dec 2006, 05:09 am by F-100 »
Gordy
« Reply #68 on: 24 Dec 2006, 05:02 am »
8)   We tried that with Captain Humble's dac and it didn't seem to help, but I'm not sure how far away he was able to move it.  It may have only been 6-8 inches to the top of his cabinet?
Captain Humble
« Reply #69 on: 28 Dec 2006, 09:15 am »
Gordy's correct.  I've had it on top of my wall unit which gave me about 9 inches between the Paradisea and my pre.  I then tried putting it on top of my amp which put it just over 2 feet away from the preamp.
NewBuyer
« Reply #70 on: 4 Jan 2007, 10:47 pm »
Just wondering, did the hum issue ever get resolved, or is it inherent in this piece of gear? :?:
F-100
« Reply #71 on: 4 Jan 2007, 11:01 pm »
IMO, there is definitely a hum issue with this DAC when matting with certain gears. However, the hum is not audible at normal listening level  .
