0 Members and 1 Guest are viewing this topic. Read 9087 times.
I want a good projector with a decent-sized screen (I guess the ceiling height limits that too)
$10K for a (probably used) projector and screen. Is that enough to get a 1080p projector and the biggest screen I'd want down there?
I will likely do little to no work myself.
Thanks, Bob. I know very little about projectors and will not start doing research till I'm close to buying. Thanks for the price guidelines.
To the big boys, HT means a minimum 12 ft x 20 ft x 30 ft room with isolation, absorption, stadium floors, purpose designed seating, movie theater aesthetics, etc., hence the $50k price tag.
When you give up ceiling height, you also give up:Stadium seating;
Don't confuse isolation/insulation with room treatments (as some above apparently have). Isolate the room electrically and acoustically from the rest of the planet, then treat the room to sound better.
Evidently we have differing definitions of what constitutes a "Home Theater". For instance my family room is pretty much a dedicated TV room, nothing more.
