LS-6 and OB-7 speaker comparison...
0 Members and 1 Guest are viewing this topic. Read 33825 times.
Daygloworange
  • www.customconcepts.ca
Re: LS-6 and OB-7 speaker comparison...
« Reply #100 on: 19 Dec 2006, 04:57 am »
I've been experimenting with carbon fiber as a matter of fact, with the intention of using it to do speakers. There are no drawbacks that I know of, or can think of. A couple of speaker companies have employed it in speakers before.
Cheers
Ettepet
« Reply #101 on: 20 Dec 2006, 11:43 am »
Danny, how do you think the RSL II Line array design will compare to your current and planned OB's? The RSL II also has an hourglass-shaped dispersion pattern, and not a voluminous speaker cabinet.
Do you think a good OB design is better / much different than the 'artificial' method of using drivers on the speaker's rear? (I'm thinking of box coloration and such)
Danny Richie
« Reply #102 on: 20 Dec 2006, 03:06 pm »
I don't know what a RSL II is.
Ettepet
« Reply #103 on: 20 Dec 2006, 06:18 pm »
It is the announced product from Mark Schifter, Arnie Nudel and Basco (ACT 3).  I think you heard about it a few months back. ;)
Am at the office at the moment, will see if I can find a link... ah, here it is...
http://av123forum.com/showthread.php?threadid=15543 (among others)
Danny Richie
« Reply #104 on: 21 Dec 2006, 01:12 am »
Oh that's Arnie's speakers. I really haven't looked at them and don't know anything about them.
audionut101
« Reply #105 on: 21 Dec 2006, 01:48 am »
Danny,
have you heard the genesis 3? http://www.genesisloudspeakers.com/prd_3.html
I bet the RSLII will be somewhat similar.
Danny Richie
« Reply #106 on: 21 Dec 2006, 01:53 am »
I have not heard it in any way that would allow me to really evaluate it.
Brucemck
« Reply #107 on: 26 Dec 2006, 07:26 pm »
Would an O-3 be a good match as a center channel flanked by LS9's?
Danny Richie
« Reply #108 on: 26 Dec 2006, 11:15 pm »
It won't have the same dynamic capability, but the sound of it will match very well.
Brucemck
« Reply #109 on: 27 Dec 2006, 03:17 am »
If you had to pick a center speaker to "best" match with a pair of LS9's, but that had to go below a screen (max speaker height 39") would it be your O3, or something else?
Daygloworange
« Reply #110 on: 28 Dec 2006, 06:09 am »
I think and OB 5 or OB 7 center would probably be a killer center compliment to the LS 6 or 9's.
What think, Danny?
Cheers
Danny Richie
« Reply #111 on: 28 Dec 2006, 04:05 pm »
Either of those will match the sound of the line sources very well. The OB-5 and OB-7 will give you better power handling and come closer to matching the dynamic capability.
wshuff
« Reply #112 on: 28 Dec 2006, 08:53 pm »
Danny,
Are you still thinking to design a center channel specifically for use with the LS 6/9, or are you leaning towards just recommending the OB-5 or OB-7?
Danny Richie
« Reply #113 on: 28 Dec 2006, 10:02 pm »
I am still considering a matching array of some kind for a center.
Brucemck
« Reply #114 on: 29 Dec 2006, 06:57 pm »
I for one would definitely purchase a center to match the 9's I've got on order!
Trying to mate those beauties with something less than an engineered match would be a shame.
