0 Members and 1 Guest are viewing this topic. Read 192517 times.
anybody still using vpi 16.5 as their primary (sole) cleaning machine, and if so, does it work?and any advice? Most ( all ) of what I see on here is pretty old info.thx
It is a little labour intensive but the machine is relatively cheap and should last a long time... It's just as good a machine as higher priced vacuums including Loricrafts for MOST people for MOST LPs...
The VPI is an excellent machine and does a very good job of cleaning records and might be sufficient for most people. However, as someone who has owned and used a VPI 17 and currently owns a Loricraft PC-4, the Loricraft does a far superior job of cleaning LPs and the difference justified the price differential IMO. YMMV
So speaking of record cleaning - until today, I'd never HEARD of TergiKleen record cleaning fluid. The amazon thread I'm linking to below contains comments about people using it in Spin Clean RCMs, etc.So is it really as good as the claims make it out to be? Seems like a good price for a fluid that makes so much fluid, and is used by archivists/Library of congress, etc.https://www.amazon.com/Professional-Archivist-TergiKleen-Tergitol-based-Concentrate/dp/B019YI38Z2/ref=sr_1_13?ie=UTF8&qid=1473724193&sr=8-13&keywords=record+cleaning+fluid
Good topic Hantra.So far I haven't nailed my method down yet but I did purchase a used VPI HW16.5 record cleaner and some hunt brushes.[/quoteI Use Good old Fairy ...Wipe with a soft sponge , Good rinse and dry over a warm rad for a few seconds.....Gets rid of all the noise. looks good and shiny new.]
I have used a couple of home made cleaners and always use the 80hz unit....
