0 Members and 1 Guest are viewing this topic. Read 192518 times.
Some more information here: http://www.analogplanet.com/content/worlds-best-record-cleaning-machineMichael puts in better words than I can.
(1) Bingo!! WET play is the BEST vinyl play.
I made a DYI frame for an ultrasonic cleaning machine. It works good, but when its done there is a line of debris that adheres to the record when lifted out of the cleaner that was floating on the water. So I still feel the need to run it through the VPI 16.5, but the ultrasonic machine gets out particles the VPI wouldn't.
Thanks. I had several records that I had previously cleaned with the VPI that I re-cleaned with the ultrasonic and there was additional material that was released from the surface of the record. These particular records has either not been played or only played a few times since the VPI cleaning. If you have the time and inclination, the following thread has a lot of information on ultrasonic cleaning and was the inspiration for the one I made. http://www.diyaudio.com/forums/analogue-source/218276-my-version-ultrasonic-record-cleaner-25.html
