0 Members and 1 Guest are viewing this topic. Read 24454 times.
lizardBrain pointed to these in a thread on 'B200 + 2 15" woofers', they might suit you and are amazingly cheap:http://www.musicsupplycenter.com/ProductDetails.asp?ProductCode=100%2D186 .
I don't recall mentioning Linkwitz, so please don't put words in my mouth.
I meant measurement geeks like yourself.
Again, I didn't say anything about Linkwitz, Geddes, or Toole.
What I dispute is that measurements are the be all to end all.
Many fine speakers are designed and built without scientific measurements ever being done.
If the 2496 was as perfect as you seem to think then it's lack of transparencywouldn't be so commonly mentioned.
My opinion is that what I'm using is far superior.
I have the capacity of unlimited outs vs being limited to a 3-way with the 2496.
My filters use 64 bit processing vs 24 bit with the 2496.
The 2496 has far less flexibility in it's XO and EQ's.
The 2496 can't address phase correction.
These factors plus the fact that I found the Behringer to be less than totally transparent are how I justify my opinion.
If you insist on arguing for argument's sake, I'm not going to participate. I wentdown that road with you before, and you were proved wrong, so I'm not wastingmy time again.
As long as you're happy with your own system, that's all that really matters, and Iwasn't knocking your system in any way. I'm sorry that you took my comments sopersonally.
I'm able to really use the system, I'm sure I'll be recommending it, because it's far superiorto the Behringer boxes.... no multiple digital/analog conversions, total flexibility withreal computing power behind the filters and everything is handled in the digital domain,so I'm finding it totally transparent.
QuotelizardBrain pointed to these in a thread on 'B200 + 2 15" woofers', they might suit you and are amazingly cheap:http://www.musicsupplycenter.com/ProductDetails.asp?ProductCode=100%2D186 .Thanks for the link. For $20 each, I took my chances and ordered 2.
It goes without saying that whatever I post is my opinion
Ok, who needs a hug aa
Quote from: JohninCR on 22 Nov 2006, 03:32 amIt goes without saying that whatever I post is my opinionAs far as I'm concerned, this is my outlook on every post I read, on every forum, by every member.Nothing is fact when you're reading an internet forum. Unless you're wanting to take it that way.Jesus people. This isn't life ending stuff here.Let's have some fun folks. aaBob - always happy
......AJ, pardon me for being ignorant, please. But how is it that you're just over a half dozen posts and are in this situation? Do you guys know each other from elseware?
Quite correct. But this may also assume that everyone else reading may also think this way. What if someone regards this "opinion" as fact? Perhaps because they are a newbie or simply unaware of the details?
should they not be prepared to defend their position (if truthful) when challenged by someone not part of the "commonly mentioned" flock?I would hope that what I raised might at least get some to see that there are "alternate" facts to those being stated as "opinion".
BTW, did you follow the link to the JBL forum? That's one heck of a system (using DCX's ) even though its not OB. I still have plenty to learn, so I fould it quite interesting, measurements and all.
Quote from: AJinFLA on 22 Nov 2006, 02:20 pmQuite correct. But this may also assume that everyone else reading may also think this way. What if someone regards this "opinion" as fact? Perhaps because they are a newbie or simply unaware of the details?Because they're nieve? I was.Bought a lot of the "wrong" stuff, now I'm starting all over.
As for measuring, (Hmm, I'm speaking as a novice), is very usefull.
To design and tweeking systems, but you have to define what your end goal is.
I've heard speakers, and rigs that were supposedly flat
I've heard systems with a higher distorion and not ruler flat speakers sound more like the music was live.
These are generalizations not the rule, but you have to take into context what you are measuring and how it is being used.
If my memory serves, in the early days of using feedback. Engineering used as much feedback as they could, because it measured well for distorion, but ended up sounding like ,well, not so good.
In the realm of digital pictures, I listen to a article on PBS about digital images look more natural to human eyes with a little distorion. If you cleaned it up it looked worse and if you added more it looked worse. I have wondered if the same thing goes on with hearing. Human ears may not be designed to like for pure tone.
My point is, What is the benchmark for measuring?
Ruler flat across frequency spectrum or sounds great to your ears.
No. I'm OB all the way. I like the "pretty pictures" as much as the next guy, but the information contained in non-OB stuff just confuses me since it doesn't relate (usually) to OB.
It is mandatory, to end up with an Orion or a NaO or an R909. Otherwise, the DIYer simply ends up obeying Beraneks law.
