0 Members and 1 Guest are viewing this topic. Read 3987 times.
The reason for this is to minimize the ground impedance between the two units in question.
The general idea behind any good interconnect for unbalanced application is to connect both sides of the shield to ground.
The reason for this is to minimize the ground impedance between the two units in question. This should give less noise, & better immunity from RFI/EMI.
Speaking of guage what guage is necessary for IC's? I'll be using 20 guage but it seems to me that the average cd player usually outputs about 2 volts and most power amps need less than 2 volts for maximum output.Being as we're dealing with so little current I'd think 20 guage is way overkill in this application. Are there any drawbacks to using thicker wire than 20 guage? Would we be better off with say 30 guage theoretically?I see you want to keep capacitance down, does it become more or less as the wire gets thicker all else being equal?Making my own ICs for myself and a couple of other people is only something fun to do. Also I can customize lengths which is nice. In reality what I end up with should be fine and well within the boundaries of what is necessary. I'm just curious. Thanks
Don't agree, Dan.If the "shield" is just that - a shield - and there are two wires underneath it ('hot' and 'return') then connecting the shield at both ends puts it in the signal path (together with the 'return' wire). I only use solid-core wire in my system so it is unacceptable to me to have braid as part of the signal path.Hence I only connect the shield at one end (source) so the braid is earthed and thus able to act as a shield but is not in the signal path.
Quote from: andyr on 19 Nov 2006, 11:15 pmDon't agree, Dan.If the "shield" is just that - a shield - and there are two wires underneath it ('hot' and 'return') then connecting the shield at both ends puts it in the signal path (together with the 'return' wire). I only use solid-core wire in my system so it is unacceptable to me to have braid as part of the signal path.Hence I only connect the shield at one end (source) so the braid is earthed and thus able to act as a shield but is not in the signal path.In my former life as an electrical enginerd, this is what I was taught: if you ground both ends of the shield, you'll cause a ground loop. Thus, you only ground one end. I would think the signal end would be the best end to ground, but I have no data to suggest this.
Quote from: ctviggen on 26 Nov 2006, 05:28 pmIn my former life as an electrical enginerd, this is what I was taught: if you ground both ends of the shield, you'll cause a ground loop. Thus, you only ground one end. I would think the signal end would be the best end to ground, but I have no data to suggest this.Re. "which end to ground" ... not being an EE either, I have no "scientific" basis to back this up but people seem to recommend grounding the source end as this, relatively speaking, is the low noise end. Except in the case of phono cables which need to be earthed at the destination end.Regards,Andy
ok I am confused. I have read that attaching the sheild to one end is the way to go. The article here on ground loops is one of them.http://www.passlabs.com/articles.htmWhile it was not written by Mr Pass himself I do trust he would back it up and I respect his designs quite a bit. Can you please in laymans terms point out where thier theory is incorrect?Thanks
