0 Members and 1 Guest are viewing this topic. Read 11786 times.
I considered foam masks on either side of the mid panels, but realized it would take a full 3" thickness to be effective down to 200Hz, cosmetically not an enhancement.
Thanks for the reply John. Foambymail.com also has the 3" Wedge foam in a 24" x 48" x 72" sheet for $115. That should work just the same I think. Also- I don't need the extra foam since I just treated my entire room with Eighth Nerve Products- they work very, very well. What do you think of this product under the RM40s?http://www.symposiumusa.com/svelte.html Just scroll down to placement under speakers.I own a couple of there products and think they are quite good. Symposium is about 20 miles ...
The first time I read "Lapels and Hood" I wasn't thinking audio!
The tweak does work. I had my RM40s toed-in so they cross about 2 feet in front of me. After the tweak was installed something was not right for me. Vocals took on a nasal quality and lost a lot of air around them. I readjusted the toe-in so the speakers were crossing at my position and everything came into place. The soundstage is more focused with greater "individuality" of instruments within the soundstage. Vocals are natural, clean, and free of any glare. So far I have not noticed any negative effects and I am really enjoying my RM40s a little bit more. In my system, it certainly did not produce dramatic effects, but that last little 1 or 2% improvement is realized. It certainly is easy and cheap and can be taken off when not in use or if it doesn't work. Can't really explain the toe-in differences, but they were necessary after the foam was put on. John, maybe you can verify this with your pair? All I need now are those FST dressplates.......
Quote from: BrunoBMy speakers are 626R with black finish. Instead of using foam, I am using a black bathroom rug (microfiber, bought at SEARS, $30). Presently, two cutted pieces of rug are hold with a rubber band on the each side of the mid panel of my 626R for testing. I plan to cover the whole front panel of the speaker using a complete rug....Bruno, please post pictures of your Rug-tweaked speakers!
Jim,This is what confuses me on paper about your tweak. If you swap positions of the MW and the MB wouldn't you be trading ceiling bounce for floor bounce?
