B200 Magnet Mount
mcgsxr
Re: B200 Magnet Mount
« Reply #20 on: 22 Feb 2007, 08:46 pm »
Ahh, had not considered that the weight of the driver would cause some issues.
I like the hose clamp idea, with the slit cut in, so that it does compress, and hold firmly.
There seemed to be some interesting 90 degree elbows that should work too, with hose clamps.
Fun sharing!
