0 Members and 1 Guest are viewing this topic. Read 10948 times.
hi john your magnet mount looks great .could you provide more insight in how the parts for itcome together , what they measure.btw there is anothe magnet mount at hawthornesee linkhttp://www.hawthorneaudio.com/forum/viewtopic.php?t=419seems to be the latest fashion malcolm
I believe part of the difference has to do with the directive nature of dipole bass. Linkwitz discussesthis at length, and boils it down to a 4.8db advantage for dipole bass over boxed bass, because you'relistening to far less reflections. I think it's more than that too. Maybe it's the room and placementresulting in the rear wave reflections helping rather than hindering. Maybe it's that we perceivedipole bass differently in some way, but I doubt this aspect because I also tried a 2nd B200 as a bassaugmenter (on a 44cm wide baffle near the floor) because of reported good results by some, and those results were quite disappointing even running the B200 past xmax. It was nowhere close to how the15" driver sounds with no baffle at all at far less excursion.
... I've only seen one other person use drivers with no baffle.
the last thing I need is them realizing they coulduse one of my 15's as a swing.
