Australian Male Power plugs
HumanMedia
« on: 4 Nov 2006, 07:58 am »
Ive personally changed  over most of my HiFi plugs to high grade American ones.  Before I did I was using some premade power cables which came with Furutech Australian plugs (from VHAudio).
I often wondered when I would see soem high grade locally made plugs.  Right under my nose they are available from:
http://www.diyaudiostore.com/power/power.htm
JohnR
Re: Australian Male Power plugs
« Reply #1 on: 4 Nov 2006, 10:29 am »
Cool, thanks, good find!  :thumb:
navi
« Reply #2 on: 6 Nov 2006, 01:23 am »
Hi HumanMedia
Thanks for the plug! (I had to say it aa aa)
I prefer to use the American standard power connectors (oyaide) myself as i find sound quality above any Australian standard plugs. I also prefer the Clipsal connector over furutech. The furutechs are a bit too smooth sounding in MY system (But they could sound brilliant in your system)
Ivan.
