0 Members and 1 Guest are viewing this topic. Read 22079 times.
Let me get this right. You put the clay/Moretite between the cartridge and the headshell and not just around the sides of where the cartridge is clamped to the headshell. Effectively creating a cartridge - clay - headshell sandwich, or a buffer layer of clay between the 2 hard surfaces. Is that right?I would assume the cartridge sinks into the clay a bit when you tighten it down. Aside from the obvious rebalancing of the arm for the added weight, and the VTA for the added height of the arm at the headshell, I would guess you would need to adjust the azimuth to make sure all is square to the record again.Are you sure that the added height of the cartridge at the headshell isn't just what's improving the bass? By raising the height there you effectively dropped the rear of the arm downward, which tends to increase bass. Did you hear any change in the top end doind this tweak?Thanks,Bob
As you may know, I have been playing with this as well (isolating the cartridge). I have to admit that I never thought of the plasticlay idea. It, for now, seems like a good idea, as it stops unwanted vibrations from going up the tone arm, but the material is also rigid enough to keep the cartridge from moving.I will put some on my Longhorn Grado Gold in the Empire 598 this weekend and report back.Wayner
it's got to better mimic Cartridge Man's little 'wad' than Mortite or Plast-i-Clay.
Da wife is going to use a rolling pin and roll me out some nice 1/16" think layer of Plast-i-lator and then I will cut out a shape that is close to the footprint of the Grado gold.Because of Bob's noteworthy concerns about movement, I think I'm going to use 2 small nylon washers in between the cartridge top and the mounting plate with the Plast-i-clay in the same layer. The theroy is that the washers will snug the cartridge up better than just sitting on the plast-i-clay and yet the plast-i-clay is there to do the wonderful vibration damping. Hopefully, the washers won't transfer enough energy to cancel the effects of the plast-i-lator.I'm going to start now.W
