0 Members and 1 Guest are viewing this topic. Read 35774 times.
Don't keep us in the dark, lets hear about some of those issues ideas!
The good side is a sw for ht will be reeaalll effective!
With my cheap 600W PA amp, it's a different story.
If you want decent mid bass from this driver, you need baffle width. This is more than apparent to me when I fold back the wings on my baffles.I agree completely, when I fold the wings back on my OB system ( http://www.quarter-wave.com/Project07/Project07.html ) the bass response is compromised. So if we extend that thought, for a given driver producing bass frequencies, the size of the baffle will determine the depth and volume of the bass. An infinite baffle is one extreme and no baffle is the other. You will get bass out of both extremes but the question is how much and at what frequency. Running with no baffle is fine if it meets your performance goals. I'll stick with a baffle.
Bob,Well spoken !JohninCR,Lets put the -3 dB point at 300 Hz in your experiment. It will be near the thruth. What is your impression of putting 6 db/octave compensation from there together with a sharp bass roll-off at 30 Hz ?/Erling
If I understand you right you state that your bass is significantly improved when sound travel distance round the sides is increased from about 51.5 inches to 68.5 inches (some average) as I measure from your baffles ?
I also find your simulations regarding the Alfa-15 interesting and revealing for the Qts importance. Even though excursion for the Alfas is limited you will have ample SPL at hand, I suppose ?
Did you experience any serious resonance from your as read it solid 12 inches sides ?
There is some useful information in this thread.Give me a few minutes to split off the 'unproductive' postsOkay - done - took me a coupla minutes to RTFM
With regard to resonance I didn't express myself very clear, what I meant was the possibility of an air cavity resonance between the 12" sides.
