Replacement Screws for T7/Ultra SL Preamp Chassis
0 Members and 1 Guest are viewing this topic. Read 1297 times.
elcaptain88
« on: 25 Oct 2006, 04:08 pm »
I had to take out the (many!) screws on my Ultra SL preamp (12-inch case) to replace a bad tube this past weekend and only put about 4 back in until I was sure the new tubes were OK. Of course the Mrs. inadvertently threw out the ones I didn't put back in.
Anyone know the specs on these so I can go down to the local ACE and get some more or where to get some? I'm sure Frank has them but if they're readily available I can just get them myself. - Thanks.
avahifi
    • http://www.avahifi.com
Re: Replacement Screws for T7/Ultra SL Preamp Chassis
« Reply #1 on: 25 Oct 2006, 04:38 pm »
The screws are simple 4-40 x 1/4" black philips pan head screws.  Provide me with your mailing address and I will send you some.
Frank Van Alstine
avahifi
« Reply #2 on: 26 Oct 2006, 10:57 pm »
The hardware is on the way to you.
Frank
