Recommendation of a tape to DVD program
0 Members and 1 Guest are viewing this topic. Read 1061 times.
budyog
  • I don't listen to audio, I listen to music.
« on: 24 Oct 2006, 01:02 am »
I am in need of some recommendations for a computer program to record my VHS-C tapes to DVD via my computer. I have tried CameraMate "Easiest Video Ever" and it seems to downgrade the video quality.
Thanks. :D
« Last Edit: 24 Oct 2006, 02:35 am by budyog »
jkelly
Re: Recommendation of a tape to DVD program
« Reply #1 on: 24 Oct 2006, 02:15 am »
Well you can use something like a Canopus card/box to convert the analog video/
audio to DV via Firewire and save to a large drive. Then use a DVD authoring
program and DVD drive to create DVD's OR you could buy a Panasonic (or equiv.)
HD DVD recorder and record to HD - do some simple edits and output to DVD.
Jeff
budyog
« Reply #2 on: 24 Oct 2006, 02:53 pm »
Thanks Jeff. I don't know that much about this type of computer stuff, but I am checking out your suggestion with my computer geek son.
Has anyone tried this program?  "Easy Media Creator #8 or the newer version #9 Suite". I can get the 8 for around $40 and the 9 for around $80.
