0 Members and 1 Guest are viewing this topic. Read 15814 times.
550K Zin - that's worth having!
Hey Bob Reynolds,No, it had never occurred to me to try what you're suggesting. Thanks. That sounds interesting. When you suggest a high pass filter, what roll off point/rate are you suggesting? If indeed we have the same understanding of a high pass filter. My main speakers are full range transmission line types that go down to an -3 db point of 40 Hz. My sub is crossed over at 50 Hz. A lot of times I don't even turn the sub on, the mains load the room that well. It's almost redundant. Cheers
Bob Reynolds,Thanks for the link. I'm not sure if he mentions whether or not they are using active crossovers and/ bi-amping. I think perhaps he's taking in to account that the majority of home video is played on " theater in a box" systems, and perhaps mixing from that perspective. Personally, I have an extreme dislike ( more like, hatred ) for movie audio. I think it's atrocious. I watch movies on a "theater in a box" system. The lows are rolled off, and the dynamic range control is set to full, as I find they exaggerate the dynamic range way too much.
As far as my 2 channel set-up, I guess to roll off the low end to the mains and have the sub crossed over higher would have the effect of making the L+R amplifiers job of driving the speakers easier. As well as being less taxing on the mid/bass drivers of the L+R speakers, with the effect of lower distortion as a result.
Theoretically, this sounds interesting. I'd like to discuss this with Danny from GR Research, as my system consists of his AV/3 speakers and PR sub. I guess I would ask him what his thoughts are as far as phase coherency, time arrival issues and so on. ( incidentally, my sub isn't ported either, but rather has a passive radiator, and works quite nicely )
BTW, how long ago did you start using these high/low pass filters in your system? Can you describe how different it is now as to the way it performed before you added them?
