0 Members and 1 Guest are viewing this topic. Read 7122 times.
Music is relaxed, coherent, clear and dynamic, with a bit of warmth (which I like).
I get a lot of calls/emails asking about what dac do I use or recommend with the modded Olive. I do NOT use an external dac and don't have the desire to so with the modded Olive. I just connect it directly into the Signature 30 or 70s and it sounds fantastic! Keep it simple, keep it pure
Does anybody out there see this as a problem? ZLS -- since you are using it with the fixed gain dual-mono Clari-T?
Question: will the Olive "remember" the last volume setting (e.g. very low volume) even if it is off the battery for a couple of weeks? I have not yet connected the Olive direct to my amp and I wouldn't want it to start off at full volume.
