0 Members and 1 Guest are viewing this topic. Read 7624 times.
I assembled speakers for Brian for some time & quite a few of my suggestions have found their way into people's speakers/homes. I also designed speakers for people as interesting as a first cellist for the SF Ballet. The only ribbon w/ QSO is the 626R (Special biwire/biamp models sold in the past on my special orders had no QSO. B discontinued biamp 626R because of limited internal space. I suppose he'd make them w/ OXO but I'm unsure if there's enough space behind the speaker for three pairs binding post inputs.)The only 1st order is the bass low-pass. An active xo should have a high-pass for the bass to aid in integrating w/ a sub. The mid & tweeter high-pass are staggered dual-pole 1st order, equal to a sum total four normal 1st order poles of high-pass only per channel, five if you account for the bass high-pass.The mid previously had a low-pass pole, but it might have been eliminated w/ the CDW eq.I don't even want to add the number of stereo poles/channels the above non-existent active xo would require, maybe around 20 or so. SOTA stereo preamps with a sum total of two channels cost $3k to $4k. Do some basic math. I get the definite idea you have not correctly calculated the cost of the non-existent active xo that is required. When a currently commercially available active xo w/ the above features is identified, that also beats the TRTs, there's a legitmate point. Till then it's pure unadulterated & idealized conjecture, hypothesis, daydreaming &/or wishmaking. Nothing wrong w/ that, but it's nice to know what we're talking about.
It seems to me that for what active biamping costs someone could nearly upgrade to the RM/x speakers. That would be an improvement over the RM 30/40's I suspect.I've been listening to my RM 40's with their old fashioned Auricaps for the past hour which are only passively biamped. Transparency is outstanding. Actually I've never heard a better system, and yes I should get out more. No doubt active biamping would improve the transparency, but how much? A few thousand dollars worth? My system retails for around 15k. 3k is 20% of my system's retail, much less what I actually paid which is probably around 8k just guessing. I'd suspect the cost of my system's cost is ball park middle land for the average RM 30 or 40 owner.My point being that everyone has to take into consideration the improvement versus cost. For a few extra thousand dollars spending it on state of the art room analysis and treatments may be a more worthy venture. I'd bet on it.Brian has to consider what he offers to us as he needs to sell these options or not eat. Also he's tended heavily toward the high value part of the spectrum in his business decisions. I've not done the math myself but would heavily bet that Jim's estimates are correct. This means that only the most tweaky audiophile's will consider this option which is a very small part of the pool. At this point if someone can afford it I'd say the best investment is passive biamping with some sort of tube or hybrid amp on top with a decent SS amp on bottom. The upper part of the spectrum with the lightning quick planars is the perfect match for the richness of tubes. Bass on these speakers is as tight, powerful and fast as you could want which usually only an SS amp can do properly. Another problem with active biamping besides the high cost is the world of problems someone can get themselves into if they don't know exactly what they're doing. The passive crossovers are done by an expert with an obviously excellent ear. The amount of people who can do this properly are few. This is just my opinion but I don't think most people should be messing with active biamping until they truly understand all that is going on and it's not simple.
So, Brian "solved" that problem long ago.I would like to see him take things to their logical conclusion, and provide a dedicated 3 way Active crosover for us RM 40 owners.
I don't know if it matters but the power output by the amp is stopped by the crossover of the speakers. In effect the current needed by the woofers of my RM 40's isn't drawn from the Fetvalve amp. This should make life easier for it and it would seem allow more power to the upper part of the speakers from this amp than if it had to output the entire frequency spectrum. If someone could explain this better I'd appreciate it btw.
Quote from: ka7niq on 17 Oct 2006, 10:23 pmSo, Brian "solved" that problem long ago.I would like to see him take things to their logical conclusion, and provide a dedicated 3 way Active crosover for us RM 40 owners.Patience Weedhopper, patience
QuoteI don't know if it matters but the power output by the amp is stopped by the crossover of the speakers. In effect the current needed by the woofers of my RM 40's isn't drawn from the Fetvalve amp. This should make life easier for it and it would seem allow more power to the upper part of the speakers from this amp than if it had to output the entire frequency spectrum. If someone could explain this better I'd appreciate it btw.In a passive xover the unused frequency is filtered off, yes, but is has still been fully amplified before being filtered off. It is still a load to the amp, just not a load to a particular driver.That is not always a waste though. Some higher powered SS amplifiers do prefer to be running closer to full tilt for their best sound. On the other side of the spectrum, many tube amplifiers sound best at moderate power ratings running and being used in a less demanding role. That is why some companies, such as Quicksilver, prefers to build moderately powered amps as opposed to the larger killer units you often see.That is how I understand things to be. If I am wrong here, please someone, set me straight.
You really hit the nail on the head about some big solid state amps sounding best at high /medium levels.
