The new O-3 (omni-directional design)
0 Members and 1 Guest are viewing this topic. Read 12788 times.
klh
Re: The new O-3 (omni-directional design)
« Reply #40 on: 3 Nov 2006, 05:37 pm »
If shortened for a CC, would the port length/width need to be alterred?
How would it fare as a CC if between two OB-5's? There is quite a difference in sensitivity.
Danny Richie
« Reply #41 on: 3 Nov 2006, 07:49 pm »
Only if you want to maintain the same tuning frequency. A center channel can be allowed to be tuned higher.
Actually it will match quite well. The sensitivity difference might not be as much as you think depending on your room. You might be sitting a little closer to the center channel than the left or right mains.
klh
« Reply #42 on: 3 Nov 2006, 09:15 pm »
Good point... I didn't think about the differing distances to each speaker!
I'm thinking about getting 5 of the O-3's for my 5 channel HT and then getting a couple OB-5's after upgrading to 7.1. Initially all would be crossed over to the sub at 80Hz (non-adjustable crossover... so it's either cut 'em off there or the run 'em full range). After upgrading to a new 7.1 pre/pro or receiver I'm sure I'll have better bass management at my disposal.
« Last Edit: 3 Nov 2006, 09:32 pm by klh »
Danny Richie
« Reply #43 on: 3 Nov 2006, 10:42 pm »
Sounds like a great plan to me.
Danny Richie
« Reply #44 on: 23 Nov 2006, 06:35 pm »
The O-3 enclosure drawings are now up on our site.  :D
http://www.gr-research.com/pdf/O-3%20box.pdf
