RA104.5 ribbon
EProvenzano
RA104.5 ribbon
« on: 2 Oct 2006, 05:07 pm »
Hello Al,
Can you tell me what the nominal and maximum power handling is for this ribbon?
I noticed the sensitivity is 97db/watt/metre from your web site.
Very nice new web site, by the way :thumb:
Thanks very much.
RAW
Re: RA104.5 ribbon
« Reply #1 on: 2 Oct 2006, 06:34 pm »
Thanks for the comments on the site.
This site has been a lot of work and still a lot more to do but yes better for sure than the old site :lol:
The power handling is rated at 30 watts as most other ribbons for its size.
So what you think of the finished pair of LXII that you had a chance to listen to here?
EProvenzano
Re: RA104.5 ribbon
« Reply #2 on: 3 Oct 2006, 02:47 am »
Very very nice Al :thumb:
What is that veneer?
If the sens of the tweeter is 97db/w/m, what would their peak output be?
My guess is 112 db per tweeter and 115 db per pair of tweeters.  Please correct me if I'm wrong.
I'm trying to estimate their dynamic range.
EProvenzano
Re: RA104.5 ribbon
« Reply #3 on: 5 Oct 2006, 04:03 pm »
Hi Al,
Would you take a stab at my question?
I didn't notice, but do you have the TS perameters available?
Thanks.
RAW
Re: RA104.5 ribbon
« Reply #4 on: 6 Oct 2006, 02:24 am »
You will be very close to the SPL you are thinking of.
 :: 104.5mm face plate
:: Six bolt holes not 4 on most small ribbons
:: Fully shielded Neo motor
:: 6 ohm
:: 30 watt power handling
:: 97db/w/m
:: 1700-40khz
EProvenzano
Re: RA104.5 ribbon
« Reply #5 on: 6 Oct 2006, 03:10 am »
Thank you Al :thumb:
