Octal Cornet
0 Members and 1 Guest are viewing this topic. Read 23146 times.
mingles
    • my system
Re: Octal Cornet
« Reply #20 on: 9 Jul 2008, 07:37 pm »
I appreciate the clarification. I'm new to this forum.
hagtech
Re: Octal Cornet
« Reply #21 on: 10 Jul 2008, 04:56 am »
I think you'll be better off making a copper or aluminum sheet to cover the bottom (glue to granite) or you'll always have hum and buzz.
Never bothered to make sticky threads.  Maybe I should have?  Personally, I hate the things.  Much prefer to see new stuff on top.  No stickys.  For an example of too many stickys, check the modwright forum.  Can't help it, I like things clean.
jh
djn
Re: Octal Cornet
« Reply #22 on: 10 Jul 2008, 04:49 pm »
Hi Jim, does that plate need to be one solid piece or can I section it to fit around all the wires coming through the base?  I also have shielding tape, would that work.  Other than the hum/buzz this thing kicks the butt of 5K phono stages.  You did a great job!!!  Cheers.
hagtech
Re: Octal Cornet
« Reply #23 on: 12 Jul 2008, 08:00 pm »
Drill holes through it.
jh
